Old 05-03-2011, 08:12 PM   #1
Pacific NW , Washington
Just finished painting, now have spots all over after drying??
Just got done painting the first half of our 59' and now we are seeing spots everywere? We sanded down the factory zolatone panels, some spots down to bare aluminum. We then coated with Devflex DTM (2 coats), then 3 coats of paint. Anyone have any ideas on what is causing this?
dgreen78 is offline   Reply With Quote
Old 05-03-2011, 08:18 PM   #2
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
A google search says it shouldn't be applied over a lacquer and I suspect the original paint you sanded may have been an oil based laquer (It looks like an oil residue leeching through).
Did you paint the topcoats with an oil base, latex or acrylic?
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 05-03-2011, 08:46 PM   #3
stowaways's Avatar
2007 27' Safari FB SE
1969 31' Sovereign
Ft. Worth , Texas
Kevin has the right idea. You need to use an oil based primer over what you've painted or a stain blocker. Then paint latex over that ... something from Aluminum is leeching through. Could be from the old paint as well -- hard to tell.
stowaways is offline   Reply With Quote
Old 05-03-2011, 08:47 PM   #4
We painted top coat with latex over the DTM. I was told by a paint shop DTM would work well over the zolatone/aluminum. Should we have gone with oil based? What to do now
Old 05-03-2011, 09:13 PM   #5
tlsmit1's Avatar
1962 24' Tradewind
Saint Louis , MO
Yikes. What a nightmare.
I am currently cleaning the zolatone with Agent Orange cleaner and scrubbing hard. After reading about the requirements of re-painting with authentic zolatone I was horrified. (Not really planning to remove all the cabinets this year.)
Cleaning helps, but I don't think it would look as good as a new coat of paint. REALLY looking forward to hearing how you solve this, as it is very much parallel to our situation.
T
tlsmit1 is offline   Reply With Quote
Old 05-03-2011, 09:35 PM   #6
reinergirl's Avatar
Hollis , New Hampshire
Darn you were given some bad advice Do a google search on "surfactant leaching". Aluminum is prone to this problem especially if you painted on a war/humid day and the night was cool. Try calling the paint company and asking for help.
Here's a short version of what I think might have happened:
Surfactant leaching
Cause Many different water-soluble materials are used in the manufacture of latex emulsion paints. When these paints are applied during hot and humid periods and expected to dry during cool evenings, the painted surface will cool, allowing dew to form. This accumulated moisture on a paint surface whose curing is temporarily delayed will extract and concentrate different water-soluble materials from within the paint at the paint surface. As the water evaporates, a concentrated residue is left behind, causing staining, unsightly runs and gloss patterns.
Aluminum siding will react to temperature changes faster than solid wood siding because of the smaller amount of material involved. Consequently, aluminum siding will develop surfactant leaching quicker and more easily; however, all siding is prone to this problem under identical conditions.
Solution Apply paint to all surfaces during climatic conditions that allow proper curing of the paint film. When “surfactant leaching” happens, flush with clean water immediately before the stains have sufficient time to set up or harden. Light scrubbing with a soft brush is acceptable. If stains cannot be removed in this manner, then repainting will be necessary during more favorable weather conditions.
http://www.intoppa.com/problems/Surf...Surfactant.htm
reinergirl is offline   Reply With Quote
Old 05-03-2011, 09:38 PM   #7
reinergirl's Avatar
I forgot to add that if this is indeed the problem USUALLY it will self correct and its a matter of waiting..... I hope indeed that thats the answer.
Old 05-04-2011, 12:30 AM   #8
Surfactant leaching
New Page 1
Good find! I think this might (fingers crossed) be the answer. We did paint late in the evening and right after a heavy rain so you might be spot on. I think we will throw in a space heater and apply another coat to see if it clears up.
Old 05-04-2011, 01:10 AM   #9
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
how...
You seem to be moving at the speed of light. Don't get me wrong, I'm impressed. Did you prewire for some additional lights? Curious as to the wires coming out of the ceiling. Also, the light fixture behind the skylight, is that original or new?
I will be painting my 58 flying cloud in the near future and will be curious to see your "detailed" results.
Keep up the good work, and keep the pictures coming!
ddstech is offline   Reply With Quote
Old 05-04-2011, 07:18 AM   #10
kevin242's Avatar
1977 25' Tradewind
Nothing to lose by trying another coat. I would recommend trying several thin coats, allowing them to dry between applications. A thick coat may allow the staining to leach through again.
If it doesn't fix the problem, stripping all of the latex and putting an oil based primer would be advised. I don't think sandwiching a layer of latex between coats of oil-based would be a good way to go.
Old 05-04-2011, 03:22 PM   #11
Thanks, yes I ran some wire for some recessed lights (same as in the new airstreams). The light fixture I picked up at Ikea for $5 My model did not come with a battery so I ran all new 12V wiring while the panels were out/loose. I plan on installing a battery box/inverter etc under the bed. I also ran wire to the fan area for a Fantastic Fan, water pump, fridge, stereo, and some outlets. Here are a few pics of the floor replacement...
Old 05-04-2011, 10:50 PM   #12
ddstech's Avatar
Folsom , California
We are following very similar paths. I put 8 led recessed fixtures down the ceiling, replaced the floor and installed new 12v and insulation. I'm hung up on finishing the belly Pan and tanks.
Old 05-05-2011, 12:51 AM   #13
Very cool, do you have any pics of your project? Which LEDs did you go with? I just ordered up one from Ebay to test out. We are hoping to get the last piece of the floor done this weekend so we can lay the cork down and get the belly back in place. Also trying to figure out if I can use Olympic rivets on the pan/C-channel or if I have to shell out for a buck riveter. Did your model have factory tanks?
Update on the paint situation... I scrubbed the spots down with a some soap and water and they disappeared! VERY happy about that!
Old 05-05-2011, 04:35 PM   #14
ddstech's Avatar
Folsom , California
My led lights are amazing, and amazingly expensive. I don't know what gets in my head sometimes. I ordered 8 lumitec orbit lights at 60.00 each. They are very small and have a brushed aluminum housing. Completely submersible, which is important to me.......
They are also recessed fixtures so they only stick out of the ceiling less than half an inch. And are about 1.5" in diameter. They really look slick and they are not overwhelmingly bright, which I like.
I'm going to get a few more for the bathroom and under cabinet lighting.
I'll post a picture tonight if time permits.
Rust spots already on rock guards - 2011 Airstream wendywoods Cleaning, Stripping & Polishing 38 03-09-2012 09:34 AM
Chrome finished vinyl insert Snaken49 Clearcoat, Exterior Paint & Trim 4 04-30-2011 08:54 PM
Painting Rear bath options SilverHoot General Interior Topics 11 04-07-2011 08:31 AM
Pictures of our almost finished 1976 Argosy 24 RV H-D Lady All Argosy Trailers 12 01-20-2011 03:18 PM
