Old 02-24-2007, 09:20 PM   #1
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
J trim
Hello... Could anyone tell me where we can get the trim that goes around the inside of the wraparound windows , it covers the edge of the wall sheeting up? Thanks Annie
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 02-24-2007, 09:41 PM   #2
MotorSeven's Avatar
Thorn Hill , Tennessee
ditto...mine crumbled also.....!
MotorSeven is offline   Reply With Quote
Old 02-24-2007, 09:46 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
I got mine from Oasis RV - Tucson AZ. Great understanding over the phone, nice postage rates, quick arrival -- the whole kit. They know their Airstreams: OASIS R.V. CENTER, INC. - Home
To give it an outside curve on the window edge you'll have to nip the underside every inch or so. Of course this does involve replacing rivets -- not a big deal.
5 meter Langford Nahanni
Old 02-24-2007, 09:53 PM   #4
1979 30' Argosy
Thanks Bob.. I will try them... Wonder if Jackson Center sells it if you visit the store.. anyone know?
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 02-25-2007, 08:25 PM   #5
1989 29' Excella
afton , Virginia
Lowes has the trim in the bath wallboard section. Limited colors...white and almond. But they work. I also had crumbling trim along the wider inserts . These are located in the bathroom and around the edge of the front ABS panel. I used the long vinyl patio blinds that I had leftover from a home improvement project. Cut these to size with a tin snipper. Slides right in.
Have pics....just having trouble posting them....help!
alumibum is offline   Reply With Quote
Old 02-25-2007, 09:02 PM   #6
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
j trim at JC
Marvin and Annie,
Two years ago when we visited the factory, they did have this in stock. We asked at the desk and the gal went back into the shop and came back with just what we needed.
Called extruded plastic J channel cap- Item #200019
At that time it was $.14/ft
You can probably call there and ask for it.
Larry and Lou
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 02-25-2007, 09:08 PM   #7
1979 30' Argosy
Thanks Lou...
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 02-26-2007, 04:11 AM   #8
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Hi Happycampers; If it is the J trim which goes over the edge of inner skins then contact Ben, at Out Of Doors Mart. 866-636-2267. Just purchased it from them. Thanks,"Boatdoc"
boatdoc is offline   Reply With Quote
Old 02-26-2007, 04:40 AM   #9
Phil and/or Sue's Avatar
1997 34' Limited
Young Harris , Georgia
Images: 40
Picture Posting Help
The most common problem posting pics is the size. The "Manage Attachments" window gives the sizes, and will reject anything larger. Digital pics can be no larger than 1 megabyte, and no wider (or taller) than 1600 pixels.
(Apparently these sizes have recently been increased to these values. I though they used to be about 400kb and 1024 wide.)
Many picture viewing software programs have a way "to re-size" then you can "save as...".
Phil and/or Sue w/ Cheryl & Penny and Roger
(Buffett RIP 9/15/08, Gus RIP 12/22/2015)
1997 34' Excella WBCCI 5936
'09 Dodge Cummins Ram 3500 Crew 4x4 auto
AIR 1753
Phil and/or Sue is offline   Reply With Quote
Old 06-15-2008, 06:08 AM   #10
Dan@LED4RV's Avatar
Denton , North Carolina
I'm sure have the trim by now
Annie
I'm sure have the trim by now, but I have had so many folks ask about this trim I thought I would add to the thread for others.
Here is a link to the "off white J trim".
Dan@LED4RV is offline   Reply With Quote
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 6 09-08-2009 06:19 PM
Trim Paint Melissa Hamilton Clearcoat, Exterior Paint & Trim 3 07-17-2004 02:54 PM
blue trim molding larry smith Clearcoat, Exterior Paint & Trim 83 12-07-2003 11:04 AM
Grey trim on the ouside of '61 Bambi windows 61BambiCanada Windows & Screens 1 05-21-2002 11:48 PM
Exterior trim ALANSD Airstream Motorhome Forums 1 04-14-2002 07:53 PM
