Old 06-26-2014, 07:45 PM   #1
r carl's Avatar
Lin , Ne
I think the interior skins are needed for shell strength.
Old 06-26-2014, 09:46 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Scrap aluminum value.
Belegedhel is online now   Reply With Quote
Old 06-27-2014, 03:18 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The interior skins work like the flanges on an I beam to strengthen the ribs. The design is a monocoque design based on Airplane design of the 1930's. It was originally taken from the designs of the Martin Aircraft company. I would not remove the interior aluminum skins. The fact that you occasionally find that interior rivets, holding the interior skin on, have been sheared to abusive treatment on the road, indicates to me that there are stresses at work between the ribs and the interior skins. Removing the interior skins will remove the possibility of the interior skins adding to the strength and rigidity of the trailer shell.
Old 06-27-2014, 08:35 PM   #4
Anchorage , Alaska
Probably right about needing the interior skins for structural stability. When I lifted my shell, I only removed the bottom row, just for that reason. Might have made it a little more top heavy, but figured it was worth it to help encourage everything to retain its original shape.
Aktundra is offline   Reply With Quote
Are these worth anything? H. Huester Electrical - Systems, Generators, Batteries & Solar 3 11-26-2009 10:36 AM
Are old appliances worth anything? photocodo General Appliance Topics 5 09-03-2009 08:19 AM
Is my '49 Trailwind Worth Anything? szym9341 Trailer Values 44 06-17-2009 03:28 AM
Are Argosys worth anything? Dr.Theopolis Argosy Motorhomes 10 06-08-2009 09:06 PM
MB 52c Dometic worth anything? goransons Refrigerators 1 07-30-2007 10:22 AM
