Old 12-30-2009, 12:55 PM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Interior Wood Wall Coverings
We are thinking of covering the wood walls in the center bedroom of our "78" Ambassador. On one wall the vinyl was peeling and partially removed. We don't want to strip the vinyl on the panels but have been thinking about covering them. Our initial thought was to use bamboo sheets cut to fit. That begs the question...how to attach them to the walls...construction adhesive, screws? What have others done with these interior walls? Looking for any and all suggestions. Really don't want to paint. Thanks!
Roadrunner is offline   Reply With Quote
Old 12-30-2009, 01:17 PM   #2
_
hi bob
a thin veneer of many solid materials can be attached over the vinyl...
IF the vinyl is in good shape and CLEANED properly beforehand.
not only wood veneers but formica or other thin solid laminates work well.
my experience was that a spray adhesive worked VERY well for ~15 years without issues.
there may be some peeling based on intense heat exposure, time or technique.
but this is a better option than screws or rivets or solid fasteners that pierce the original wall panels.
cheers
2air'
Old 12-30-2009, 01:39 PM   #3
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
2Air...would you suggest removing the wall to laminate or could it be done with the walls in their proper position? We are also considering removing the front wall seperating the countertop from the streetside bed...opening up the trailer. But I'm not sure what issues this presents with the overhead compartments.
Old 12-30-2009, 02:38 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Any time you are working with glued on materials it is a lot easier to work on the horizontal than the vertical so removal is a good idea if you don't have to disassemble 2/3s of the rig.
Any loose material should be cut away from he wall before you apply the new material to insure adhesion of the new to a good surface.
2004 Excursion 4x4
Old 12-30-2009, 04:14 PM   #5
_
hi bob
it depends on how many walls and surfaces are being redone and how easy it is to cut the templates for veneers.
for example doors that can come OFF via the piano hinges vs fixed walls.
most of my 70s unit was done without removing walls (doors and drawers) and with a roller.
many of these modern spray on adhesives are tight right away.
a/s applies the ceiling vinyl and mouse fur like wall paper, overhead and vertically after spraying both surfaces with stick'em.
the real issue with removing walls, is finding that much MORE stuff to fix and update once you are IN the spaces.
and IF there is shag carpet UNDER things, pulling interior walls is a good approach, since the carpet can be removed at the same time.
cheers
2air'
Old 12-30-2009, 07:38 PM   #6
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Veneers over Plastic
Wel said 2 Air. I left my panels in place and then covered them. Took many measurements and trimming the panels before
I put on the adhesive and used a roller to press it down. I cut the veneer to fit around the overhead bins. It probably would have been easier to remove and glue but then everything including overhead bins has to e removed. Here's a link to the thread with pics of it:
http://www.airforums.com/forums/f39/...ind-56774.html
RichHog is offline   Reply With Quote
Shower Wall Coverings - What are my options? BrockLives Sinks, Showers & Toilets 7 05-15-2009 12:19 PM
renewing interior wood paneling mjmcwhorte Cabinets, Counter Tops & Furnishings 16 01-05-2006 11:05 PM
wood interior for 62 GT B Stover Cabinets, Counter Tops & Furnishings 2 10-24-2005 02:41 PM
Interior Skin Aluminum or Wood?? BornToRock General Interior Topics 5 08-31-2005 07:33 AM
Interior refinishing wood panels Excella3287 Cabinets, Counter Tops & Furnishings 7 04-29-2003 12:07 AM
