Old 06-11-2008, 02:32 PM   #1
rogerdodger's Avatar
Fresno/Clovis , California
Interior walls-What to plug holes with??
I am getting ready to prime and paint the bathroom. what do I use to plug rivet holes with. Pefer not to use more rivets.
thanks for any help!
Roger
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 06-11-2008, 02:34 PM   #2
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Roger..... what no more rivits? Can an AS ever have enough? I filled the extra holes in the Tradewind with rivits. You might want to try a two part epoxy, fill and let set for twenty four hours, sand and then repeat before priming.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 06-11-2008, 04:28 PM   #3
The PO also added some additional brackets, which are mounted by screws, which i want to remove and fill holes. Thanks for responding.
Roger
Air# 29488
Old 06-11-2008, 04:56 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Another Possibility
If not rivets, how about titanium jewelry?
Vaughan
Old 06-11-2008, 05:09 PM   #5
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
I'm using rivets simply because I think of anything else that's more affordable.
www.nesa.org
Air No. 6427
Old 06-11-2008, 05:15 PM   #6
1972 25' Tradewind
Madison , Wisconsin
Stop shooting mice inside the trailer! A lot less fun but it does cut down on the amount of body work...(BB guns only make dents!).
Smokin Camel is offline   Reply With Quote
Old 06-11-2008, 05:26 PM   #7
ok, next question. I have never riveted, so, where do I get them, the tool etc. Lowes, Home Depot, ??
Roger
Air# 29488
Old 06-11-2008, 05:38 PM   #8
Got gandkids?
HomeyD's or Lowes will have what you need. Get a small pack (50 per) of 1/8" diameter, 1/4" draw and 3/16" diameter, 1/4' draw pop rivets. They sell a tool that will handle either sized rivet. Total cost around $30 to $40.
www.nesa.org
Air No. 6427
Old 06-11-2008, 05:46 PM   #9
ok. Do they need to be aluminum?
ROger
Roger
Air# 29488
Old 06-11-2008, 06:03 PM   #10
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
Roger:
You don't need to use rivets unless you want to. You can easily fill the holes with auto body filler.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 06-11-2008, 06:09 PM   #11
HowieE's Avatar
Princeton , New Jersey
Images: 12
ROger
If you do use rivets use aluminum. In the bathroom water and steel will not mix, rust.
As for installing rivets it is a no brainer with the tool.
2004 Excursion 4x4
Old 06-11-2008, 06:10 PM   #12
1966 30' Sovereign
1963 22' Safari
orlando , Florida
toilet paper
richie rich is offline   Reply With Quote
Old 06-11-2008, 06:15 PM   #13
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Okay, so you don't see all the shiny silver rivets all over the place, dab a little white correction fluid (like for a typewriter) or white liquid shoe polish on the head of the rivet after installing. They will then blend in pretty well.
Old 06-11-2008, 06:54 PM   #14
Got gandkids?
Yep, use aluminum. The steel will rust, etc, as others have pointed out. Also, model airplane paint or nail polish works, as well, to cover them.
I think I'm comma challenged tonight.
www.nesa.org
Air No. 6427
Redoing interior walls tslanier Upholstery, Blinds, Walls & Interior Finishes 7 11-23-2007 08:04 PM
Interior Walls tique79 Upholstery, Blinds, Walls & Interior Finishes 1 06-02-2007 03:16 PM
What Are My Interior Walls Dano57 Upholstery, Blinds, Walls & Interior Finishes 4 07-24-2006 06:01 AM
interior walls happier General Interior Topics 7 07-02-2005 01:04 AM
Interior walls dmadam Upholstery, Blinds, Walls & Interior Finishes 0 10-27-2004 05:59 PM
