Old 04-19-2011, 07:52 AM   #1
1970 21' Globetrotter
new orleans , Louisiana
Interior walls
Is there a layer of aluminum on the interior of the vintage airstreams? When you see pics of those renovated airstreams that have the inside panels shiny aluminum was that added or is that under the wall material?
jhirstius is offline   Reply With Quote
Old 04-19-2011, 08:04 AM   #2
The is aluminum on the inside walls and has been from almost day one.
It adds strength to the "monocoque" construction.
Old 04-19-2011, 08:09 AM   #3
Thanks andy, How hard is it to pull the interior wall out and expose the aluminum for polishing, does the trailer lose any structural integrity if you do that?
Old 04-19-2011, 08:24 AM   #4
The interior walls are held in place with "pop" rivets. They can be drilled out with a # 30 drill bit.
However, the trailer must be placed on jacks, so that the shell does not sag at all, when you remove that metal.
But, the better part is, why do you want to remove the metal? It can easily be stripped of it's vinyl coating and polished while still on the walls.
That would take a little more effort, but far less than removing the metal for polishing.
Old 04-19-2011, 09:04 AM   #5
Eliminator46's Avatar
1970 25' Tradewind
Cleveland , Texas
Images: 45
Are you refering to the coating on the face of the aluminum?
Eliminator46 is offline   Reply With Quote
Old 04-19-2011, 09:12 AM   #6
1970 25' Tradewind
Cleveland , Texas
Images: 45
That is a vinyl coating. There are some very informative threads in the restoration portion of the forum for walls, upholstery and so forth.
Old 04-19-2011, 12:00 PM   #7
thanks I did not realize the the aluminum is actually covered with vinyl I thought it was a laminate skin. I appreciate everyones advise.
Old 04-19-2011, 01:45 PM   #8
jackson center , Ohio
Some interiors had zolatone paint over the interior aluminum skin.
Schu is offline   Reply With Quote
Old 04-19-2011, 01:50 PM   #9
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
It being a 1965 absolutly zolatone! We all know how much fun that is to get off. Do-able but not always fun.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 04-21-2011, 09:47 AM   #10
mrsfixit's Avatar
1969 31' Sovereign
Twin Lakes , Wisconsin
Images: 21
How do you get that Zolatone off?
1969' 31' Land Yacht Sovereign project
mrsfixit is offline   Reply With Quote
Old 04-21-2011, 11:09 AM   #11
AndrewM's Avatar
1954 25' Cruiser
Nashville , Tennessee
One way
Dirty Jobs |
Here is how I did it. It is fairly simple just a lot of elbow grease.
The blog of Airstream brothers: www.airstreamfever.com
AndrewM is offline   Reply With Quote
Old 04-21-2011, 03:31 PM   #12
mrsfixit's Avatar
1969 31' Sovereign
Images: 21
Originally Posted by AndrewM View Post
Dirty Jobs |
Perfect. Thanks!
Old 04-21-2011, 04:20 PM   #13
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Dirty Jobs |
Zolatone was used from the mid-50's to the mid-60's when they transitioned over to the vinyl-clad aluminum panels. '65 is a transition year that has both...but I think after that, it is primarily vinyl. Removing the vinyl is a very different process than removing the Zolatone - neither one are what I would call fun...depends on your year which is your challenge ~
Shari
Old 04-21-2011, 08:24 PM   #14
Ottawa , ON
Personally, I'd think twice before launching into removing Zolatone, if I had it.
Really, it's not an unpleasant coating, and secondly, it is low maintenance and goes well with any colour scheme.
renovation, inner skin
