Old 05-28-2019, 04:35 PM   #1
Delaware , Arizona
Interior wall screws on 2019 Flying Cloud
I'm a novice Airstream owner. A screw that holds one of the dinette sliding blind brackets to the wall fell out. Are replacement screws something I can buy anywhere or do I need to order from Airstream? If the original fell out is there something I should do for the replacement so it doesn't fall out too?
sowgeeky is offline   Reply With Quote
Old 05-28-2019, 04:41 PM   #2
2015 25' FB Flying Cloud
Sandy , Utah
You can get Pan Head Sheet Metal screws at any hardware store. Make sure to buy Stainless Steel. It screws into aluminum and Stainless will not react with the aluminum.
rocco52 is offline   Reply With Quote
Old 05-28-2019, 04:48 PM   #3
2014 25' FB Flying Cloud
Kingwood , Texas
I have a 2014 that has a screw in the blind bracket that fell out once. I just just put it back in and tighten it up and all is well. You could just get a little larger diameter screw to replace if the original one won’t tighten back up, but no longer than the original. Your local home improvement store is a good source for replacements. You could even get a stainless steel screw if you want to.
DoubleR is offline   Reply With Quote
Old 05-29-2019, 01:20 PM   #4
Delaware , Arizona
Thanks all! Are they typically 1/2" long?
GMC 1500 AT4 2019 & Airstream Classic 30RB 2019 mikebrownvb Towing, Tow Vehicles & Hitches 54 07-15-2019 12:33 PM
Cloud Pleaser :: 2019 Airstream Flying Cloud stevejant Airstream Registry Discussions 0 05-24-2019 10:25 AM
2019 Flying Cloud AC Cover Screws Life is a Highway General Repair Forum 0 04-16-2019 02:24 PM
2019 Flying Cloud vs 2019 Serenity SnooMc Buyer Guidelines 5 02-17-2019 12:23 PM
Any news on 2019 interstate on new 2019 Sprinter. jagzoo Sprinter and B-van Forum 4 11-18-2018 06:15 AM
