Old 05-06-2003, 12:32 PM   #1
Interior Paint--Vintage Trailers
OK, so I found my local "agent" for Zolatone paint.
After 6 weeks of trying to schedule a "look see" and bid for painting the trailer, I called today and was told that "the owner" doesn't want to do it. When I asked why, he said he wasn't sure about that application. When I told him that Zolatone was the OEM for Airstream for decades, the next reason given was "We don't want the liability."
So....these questions:
1) Should I paint it at all? There's no scratches, but it looks dingy. (I've been over it 3 times with Simple Green and citrus cleaners.) Will a quality paint job adversely effect the value?
2) Has anyone applied Zolatone himself/herself, and if so, how hard was it? The Zolatone site seems to suggest that there's some measure of skill involved (But if the monkeys I talked to on the phone today can do it, I'm encouraged).
3) Can anyone suggest an alternative that is: a) easy to apply; b) original looking; and c) durable?
Thanks for your help, Tom
63flyingcloud is offline   Reply With Quote
Old 05-06-2003, 10:51 PM   #2
I don't care for the look and Idon't care about the value....cigarettte smoke yellow/tan-or should I call it lung cancer color- looks like crap. I scrubbed with with Krud Cutter and rinced it with clear water and again with vinegar water till the rinse water was clear.....painted it with Porter 184WB and let it dry of a week now I can put anything I want on it...laytex or enamel......Porter Paints tried it on a sample and It stickes and won't peal if ou get it clean.....geof<anything will look better than lung cancer yellow>
geof is offline   Reply With Quote
Old 05-06-2003, 11:14 PM   #3
silverhawk's Avatar
1964 22' Safari
Elyria , Ohio
Images: 20
Send a message via Yahoo to silverhawk
Tom, At H.D., a cleaner by ZEP, Citrus cleaner & degreaser. This stuff cuts that crud better than any thing that I have tried, and I tried many products. Simple Green had been about the best I had found until this ZEP stuff. It's orange comes in spray bottles, and refill jugs. Give it a shot you will be smileing. Gloves are optional but recemended, rinse with clean water. Bob,
silverhawk is offline   Reply With Quote
Old 05-06-2003, 11:24 PM   #4
Home Depot ZEP Products are watered down IMHO....Krud Cutter will clean it-if it can be cleaned.....Zip Rezeppa was my old sales/rep for ZEP Chemicles in the '70's.....I think he is still in Jail for Insurance Fraud.....good enough for him....he even ripped off my kick backs.....geof
Old 05-06-2003, 11:32 PM   #5
silverhawk's Avatar
1964 22' Safari
Elyria , Ohio
Images: 20
All I need to say is that I tried a sample that I got for free. It cut through the grim that was on the inside walls of my 64 Safari like nothing else that I have found. Bob,
Old 05-07-2003, 10:15 AM   #6
what works for you-works best for you.....I offered an aturnaltive cleaning product-which with one spray bottle-cleaned all the lung cancer yellow off the whole inside of my '27 Overlander.....the guy that did the sh*t work only charged me $30 for 3 hours work.....It was the best deal I have ever had!....the girl who works for me went over the same inside top to bottom for $36 which took her 4 hours to do the whole thing twice....it's done and is painted in 184WB Porter on the walls=the floors are to be done with an oil Porter 164 this weekend.....then I start doing th finishing up.....geof
Old 05-07-2003, 10:43 AM   #7
Thanks, guys. I did try the Zep, and while it helped a lot, I'm still dissatisfied. Maybe I'll try the "Krud Kutter" before deciding to paint.
Man, I've already got about 8 hours in scrubbing the walls, and I've got to say that it's not putting me in the mood to polish.
God, I love this Airstream stuff! Can't wait to actually use the d**n thing!
Old 05-07-2003, 11:04 AM   #8
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
See I'm having to udo the mess in ours. The PO (my Father-in-law) painted the inside with semi gloss house paint...baby blue no less. Looks great with the brown couch! NOT. So we have to strip the bad paint job and then start over.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 05-07-2003, 11:22 AM   #9
Thanks, Toaster. Just when you think you've got it bad, someone comes along on this Forum and let's you know that it could be worse.
There's a lesson for life there, I think.......
( The lesson is "BUY NEW!")
Old 05-07-2003, 11:48 AM   #10
removing paint could go easy or could be the hardest thing you have ever done in your whole life....depending on the materials used for stripping.....contact the manufactures first for their recommondations.....I had a peeling/flaking/not drying situation on aluminum which I used Liquid Nitrogen on a large swab......when the surface warmed up all the paint chipped and fell off on the floor and I sucked it into a vacuum cleaner....it was a lead based paint that had to be removed form a childrens hospital so sanding & chemicles were out....geof
Old 04-21-2004, 11:30 PM   #11
fake zolatone
have done this to a couple trailers now.paint the inside of the trailer with a base coat,your pick. then go to home depot/lowes and get american accents paint, stone creations.spray. your pick.carefully mist the paint from about 2 feet away.to close gets muddy,or stripes.may want to try on something else first .can apply lite coats at first,let dry or will get muddy.then to desired tone.drys ruffer than zolatone but comes close to the look.cost me 60.00 to do 20 ft trailer
buddysrvpark is offline   Reply With Quote
Old 04-24-2004, 09:58 AM   #12
Over59's Avatar
Putnam , Connecticut
Images: 37
http://www.rightergroup.com/product_...y_zolatone.asp
Over59 is offline   Reply With Quote
Old 04-24-2004, 01:22 PM   #13
I just used that over Krylon Plastic primer for the front end cap. It really looks great.
Mark
Old 04-29-2004, 07:59 AM   #14
Send a message via Yahoo to silver suz
Have I misunderstood? After cleaning the ABS bath plastic, can one use fine sand grit and a wax to finish it off?? silver suz
silver suz is offline   Reply With Quote
Vintage sub-units? Midamrail WBCCI Forum 47 12-10-2006 08:53 AM
vintage vehicles to match trailers femuse Our Community 22 05-05-2003 09:20 AM
Vintage trailers for sale . . . Hubba Our Community 1 12-28-2002 02:18 PM
Vintage Minitrailers babycakes Our Community 13 12-12-2002 03:46 PM
How vintage is vintage? zamboni On The Road... 9 12-02-2002 03:30 PM
