Greetings Susan!
How did you get your sink and tub so clean?
The original fixtures were Avacado Green with brown and yellow blotches for accent when I first acquired the coach. Tried every cleaning process suggested, and experienced very little success - - cleaner but still stained and in a color that I never really cared much about being in contact with on a recurring basis.
The process was actually called a coating system, but the components were applied like most automotive finishes. The local contractor used at least three different primers and top coats to account for the different materials used in the bath - - fiberglass, abs plastic, and a non-specific plastic that reacted differently than the known fiberglass and abs components in the bath. The results were nothing short of fabulous - - and the bath has been in use the better part of two seasons now and it continues to hold up quite well - - I am rather careful with cleaning , but no more so than with the fiberglass bath fixtures in my home.
This was the starting point on my '64 Overlander:
Good luck with your bath project!
Kevin
