08-04-2003, 09:56 AM
Interior lining
How are the interior walls of an AS made, i am starting to check out some As units but dont understand the interior wall structure.
Am i looking at a lining backed by foam insulation with metal frames and outside metal skin. I often see crinkling or spot warping of lining and wonder how to fix it.
Bruce
08-04-2003, 10:28 AM
Contributing Member
Austin (Hays County)
Interior walls ...
are aluminum sheet. Not as heavy gage as the outside walls, more like the thickness of the end caps.
Depending on the year and model, they may be coated with various finishes: Zolatone paint, foam backed vinyl, fuzzy cloth, or simply polished (current CCD line).
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
08-04-2003, 10:39 AM
Just a member
1978 28' Argosy 28
Lutz
Crinkling or spot warping of the lining is not a good thing. If there have been that many rivets that popped ther may be somthing wrong in the structure of the unit. Normally if a rivet pops it could just be from wear as the units flex and bend as they are towed. Many popped rivets along a rib line can be a problem.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
08-04-2003, 11:00 AM
Thats a big help, i didnt realize there were several finishes. I will note the info on the warping as well. Thanks
Bruce
08-04-2003, 11:21 AM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Also from '65 to sometime in the 70's, vinyl directly glued to the aluminum without the foam backing...
Shari
08-04-2003, 12:08 PM
I have looked at several 96/97 wide bodies, that seem to have "headliner droop".......any comments?
George Jr.
08-04-2003, 12:33 PM
Contributing Member
Doesn't have to be old!
My 2003 International AS had an area of the fuzzy headliner drooping over the bed. The droop started as soon as it got really hot last summer. I popped out the trim strip and found that the affected area was tacky to the touch but not enough to hold the fabric. I sprayed the area above the liner liberally with 3M spray adhesive and it has been fine ever since..
John W. Irwin
WBCCI #9632
08-04-2003, 03:10 PM
1999 34' Limited
2002 19' Bambi
Allen
The recent adhesive must be pressure sensitive
The "fuzzy" lining material used over the last few years seems to be applied with a pressure sensitive adhesive. Our '02 Bambi had several "bubbles" where the adhesive had turned loose. The local A/S service center did take care of the original issues but then a few smaller ones (several inches across) starting showing up, noticable especially at night when the shadows from the lighting would accentuate things. I decided to see if I could fix the problem area by just using considerable pressure in the affected area. I used a broad, clean plastic tool handle and really put some pressure behind the effort. I can report that I was successful. The areas I reattacted with pressure alone have remained attached. In addition, there have not been in new areas.
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
Past President Heart of Texas Camping Unit
WBCCI # 7548
08-04-2003, 03:54 PM
"Also from '65 to sometime in the 70's, vinyl directly glued to the aluminum without the foam backing... "
This was used into the late 80's, at least. Tough, but acquires a sticky feel to it that is not appealing. Inland RV recommends Futura Floor Wax to end the stickiness.
"I have looked at several 96/97 wide bodies, that seem to have "headliner droop".......any comments?"
This was a manufacturing issue, and it is well covered in the archives, somewhere. I do not know the range of years, but the problem appears to be that the foam itself disintegrates, and so the vinyl sags. There is apparently no simple solution in those cases. I understand some fortunate owners had theirs replaced under warrenty.
Mark
08-04-2003, 04:00 PM
1999 34' Limited
2002 19' Bambi
Allen
I have seen the the foam disintegration problem
When we had our '02 Bambi at N Dallas RV last year, the guys commented on the newer material used in our unit. They took me into several units (MH and TT) where the whole headliner section had fallen due to the foam backing disintegrating. It was pretty apparent that A/S did not do any lifespan studies when selecting that product. While the new CCDs interior walls may be prone to scratches, at least they will never have to deal with the interior material falling off the ceiling or walls.
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
WBCCI # 7548
08-04-2003, 09:50 PM
St. Cloud
Re: I have seen the the foam disintegration problem
So does anybody know if the interior aluminum has Plasticote finish on it (needing the care associated with that -- Walbernizing or whatever else...)?
08-05-2003, 03:37 AM
Just an old timer...
2004 22' Interstate
Tipton
, Iowa
Re: Re: I have seen the the foam disintegration problem
I guess we're fortunate in that our nearly ten-year-old foam-backed headliner is hanging on with (so far) no problems! I hadn't even considered that to be an issue when we bought it! Having never had a unit newer than '85 before, how widespread a problem is this? Is it only in the wide-bodies, or all trailers with the foam backed headliner?
It's my understanding that the new aluminum is coated at the Alcoa factory, pre-installation. Since the interior isn't exposed to weathering, I should think that an occasional wipe-down with a mild soap and water solution should keep it looking nice for years. I don't think an occasional coat of Walbernize would hurt anything at all, but I'd doubt it would be necessary.
Roger
havin' to fix my broken Airstreams since 1987...
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N DODGE Sprinter
02-02-2004, 10:35 AM
Elgin
Re: Interior walls ...
I've looked at a couple of '91 Limiteds that appear to have vinyl adhered directly to the ceiling and sides, no foam backing, so I guess it was something still done at least into the early 90's?
02-02-2004, 10:52 AM
1965 20' Globetrotter
1956 22' Caravanner
Mendon
, Massachusetts
Removing Vinyl coating
I recently bought a 71 Safari that has the vinyl coated aluminum and was wondering if anyone has every removed it and polished the aluminum. I'm assuming that since it is 'vinyl' maybe one of the leading paint strippers might do the trick.
02-02-2004, 11:11 AM
I mentioned this on another thread that when it is
cold the interior aluminum aft of the ac about four feet pops down or sags and looked terrable. When it's warm it wont' sag. I glued a rubber spacer just in front of the light aft of the ac between the outer and inner skin and that keeps the sag to a miminum.
