Old 02-03-2005, 01:35 PM   #1
Interior color change
My interior is painted white. I want to change it. I like the look of brushed- AL. Has any one sandblasted their interior? There seems to be blasting material made to remove paint from delicate surfaces, so this should be possible.
Will
William8979 is offline   Reply With Quote
Old 02-03-2005, 01:46 PM   #2
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Paint remover. Its a long tedious job. I am in the middler of removeing two very poorly applied coats of paint.
The end caps are not aluminum after about 57 I know but might be as early as yours. From around 57-65 they are fiberglass and I think around 65 or so it went to a ABS.
Your interrior aluminum is more then likley not as nice a grade as the exterior. Probably a 6061 instead of the T2024t3 Alcad the exterrior is. Thats how our 59 is.
In the photo albums is picturs of a coach painted with a nice silver that deals with the endcaps not being aluminum. Came out very nice. TinCanLuv used aluminum flashing to deal with the end caps and it came out quite nice. Again pictues of the build are posted in the forum and in their photo album.
Several posts about stripping in the interrior restoration section of the forum as well.
It could be blasted if its a ll aluminum. I would hire it out to somebody that used walnut shells. That will be soft and not likly to damage the aluminum.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 02-03-2005, 02:04 PM   #3
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
You can also blast with baking soda -
My 58 has aluminum ends....
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
