Old 11-04-2004, 09:12 AM   #29
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I used some of the flashing type aluminum sheet from HD on my door, at the bottom where the vinyl looked crappy. It dents pretty easily and would probably not be the best for the interior in that it might not hold up too well over time.
For the door bottom it looks ok, but the screen door still marks a black streak on it as it did on the vinyl. I keep the screen door clean, and even put some metal tape over the area that rubs..better but not yet solved.
Might have to put some material in a strip across the door where it rubs.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 11-04-2004, 11:20 AM   #30
alclad
Try looking at the online catalog of "Airparts", you can buy any thickness of 2024 T3 Alclad as used in for aircraft skin. They will cut it to size and roll it for shipping. You will love the appearance of alclad.
sidneygruber is offline   Reply With Quote
Old 11-09-2004, 06:41 AM   #31
josephhh's Avatar
1979 24' Airstream Excella 24
Macon , Georgia
Thanks guys for the inputs. The FX Sheeting looks like an interesting alternative. I guess I'll go out and remove one of the window trims to see how that works. Seems like I recall Andy's new trailer having some cool looking big rivets running around the inner window frames. My frames only have a few little rivets. I reckon I could add the big ones for looks? I'm very suspect of the "stickiness" thing with the current old vinyl covered aluminum. I understand that the old glue oozes through the vinyl. I am curious what effect this has on today's adhesives sticking to it. Do you all think today's peel and stickum products will stick to it permanently?
I need to go sit in the motorhome and stare at the walls for an hour...
josephhh
josephhh is offline   Reply With Quote
Old 11-09-2004, 11:11 AM   #32
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
The alsa aluminum sheeting stuff looks awesome. It would be great to use the brushed aluminum look inside our Moho's. Its 30 bucks a square foot which is not too bad, and supposedly it can be hand formed around corners and such. I wonder how it would look over the plastic cabinets?
AIR #005
retired!
Old 11-09-2004, 12:11 PM   #33
josephhh's Avatar
Macon , Georgia
I agree Alan, that it looks good, but those 30 dollars are going to add up pretty quick aren't they? We need a bulk deal here.
Old 11-09-2004, 12:17 PM   #34
josephhh's Avatar
Macon , Georgia
The interior of Andy's new trailer illustrated (to me) the value of having the contrast between the metal and the wood. His interior aluminum was very clean and stout looking. The wood cabinets made for a nice mixture. I think it might be too much to cover the walls and cabinets with Aluminum. I've got a cabinet maker living across the street and he said he can duplicate my plastic overhead cabinets pretty easliy in wood. That's what I'm thinking...
Old 02-24-2005, 09:14 PM   #35
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
end cap question
Here's a picture of our end cap area in the front. I'm seriously debating putting in new aluminum on the inside except for end caps. Husband says he can fiberglass over the bathroom (rear) end cap and perhaps over the front; we're putting in a u-shaped dinette there.
Any ideas, pro or con, to the fiberglass idea? Is aluminum on the end caps really hard? I would think so.
What thickness aluminum is recommended?
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 05-12-2017, 09:44 PM   #36
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
I googled "airstream aluminum interior" and this old thread popped up. I want to remove the mouse fur from my 95 Excella and install new interior aluminum over the existing aluminum wall material (presently covered with glue).
I am thinking the best material to use would be the same as Airstream uses on the new trailers. I would like to know the specific material and the thickness. I am also thinking that the material thickness could be thinner as it is going over existing material. I don't want to add unnecessary weight.
Thanks, Dan
Old 05-13-2017, 07:07 AM   #37
1975 Argosy 26
1974 29' Ambassador
1968 20' Globetrotter
Whiterock , British Columbia
I'm in the process of re-skinning the interior of my 29'. I'm using .032" 5052. The amount of weight using that thickness (same as factory I believe) will be inconsequential. It's not going to be any easier using thinner material.
Have you done anything like this before? It's not exactly an easy project. It is also very time consuming. Not trying to dissuade you, just giving you the benefit of my current experience. I am what some would call a highly skilled tradesman with a background in both high end finishing/cabinet making and metal fabrication/welding. I have a very well set up shop too. Again, I'm not trying to talk you out of the project, but just trying to give you an idea of the reality of the job.
I should add that I have a client with a mid '90s Excella who is in the process of stripping his mouse fur prior to us doing an interior renovation on it. He has apparently had some success with stripping the glue. I haven't seen his trailer in about a month, so I'm not sure what the end result is looking like.
I am the '68 Globetrotter...
redthies is offline   Reply With Quote
Old 05-14-2017, 06:06 AM   #38
muddy_hollow's Avatar
1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Send a message via AIM to muddy_hollow Send a message via Yahoo to muddy_hollow
I would agree with Redtheis that this is not an easy project. I reskinned the interior of our '56 Caravanner using the original sheets as templates. I saved the end caps and used aircraft stripper to remove the zolatone. What a rough job that was.
The trickiest parts are around the door and the ceiling panel. Everything has to line up right. I used the same thickness and type of aluminum used by the company and I would caution you not to use something else. The door area needs to stretch a little and I was fretting a rip. Nothing like that happened but was on my mind.
Also get a couple helpers.
ID:	285479Click image for larger version
Not the best photos of the project but you can see glimpses of the new skins and the polished cap. Also you will see every finger print so you'll need to polish the interior every so often. Exactly what I wanted....,more polishing time
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Old 05-14-2017, 06:11 AM   #39
1956 22' Caravanner
There's another thread on plasti dip for the exterior but that would would be an interesting use case as an interior coating.
Old 05-15-2017, 08:31 PM   #40
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Muddy Hollow and Redthies
Thank you both for chiming in. This is exactly what I was looking for, some input based on experience. What I am planning on doing, I believe, is no where as difficult as what you guys have done. First off, the ceiling. I have the dreaded vinyl ceiling that is coming unglued. Fortunately no end caps are involved. My plan is to remove the wall cabinets and then the vinyl material and then strip the glue from the aluminum. Once this is completed I want to paint the aluminum white along with the plastic end caps, fantastic fan plastic and skylight plastic. The big question here is what to use for stripping the ceiling glue from the aluminum. What do you recommend?
I want to remove the mouse fir on all the walls. I then plan to cover the aluminum with the same product that Airstream uses for the new Airstreams. I don't know Airstream uses. I just bought some aluminum from Airparts, Inc to make some repairs to my 66 Tradewind- .032 2024T3 Alcad Aluminum for the exterior and .025 5052h32 aluminum for the belly pan. The interior panels may be the same material as used for the exterior panels. I really do not know.
As far as my skill level I would put my work at a "B" level when compared to other work I have seen on Airforums. I have done lots of work on houses (rough and finish carpentry, plumbing, electrical, hvac). I have also done lots of work on cars. I am completely self taught. I have no sheet metal work experience. I will be getting some soon working on my 66 Tradewind.
Thanks, Dan
Old 05-16-2017, 04:58 AM   #41
1956 22' Caravanner
Thanks, Dan
Aircraft stripper is the strongest that I know of. All caveats apply; respirator, goggles, gloves, and a bucket for your arms just in case.
Good luck on the vinyl. It's rough stuff to remove but the stripper might work. You might just want to paint it over and save some time.
I'm a software guy and had never done this type of work before so you should be well skilled for this.
Good luck
