Old 11-05-2015, 03:31 PM   #1
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
Interior aluminum ceiling rails
I was wondering if anyone has ran into my situation of the aluminum rails that hold the two foot wide center pieces to the ceiling being about a foot short on each end when I put them back up. The PO had removed them prior to purchase, so not sure about them. They don't look bad but don't need the sheets coming loose going down the road. Thought about spacing some rivets on each end to help secure and look descent. These are in a 1972 31' Sovereign, the rails are 18' long and don't appear to have been cut on. Any input would be appreciated.
cole3444 is offline   Reply With Quote
Old 11-08-2015, 06:23 PM   #2
1971 31' Sovereign
1972 31' Sovereign
Ceiling rail tracks
Since no one has had this problem on short rails does anyone out there have the tracks that are not the full length and could you tell me how the last foot of sheeting on each end is attached. Does anyone know where I could find about 4' of this track, two pieces at 2' long will work also if I decide to redo my tracks. Thanks Jim
Old 11-08-2015, 06:50 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I don't know, but to the best of my recollection my tracks ran full length.
I think that riveting up the last foot or so of center panel would have no implications.
In fact, since my inside aluminum panels are now not visible, the full length of my center panel is screwed in, and not in the grove at all.
Brevi tempore!
Old 11-09-2015, 06:16 PM   #4
1971 31' Sovereign
1972 31' Sovereign
Interior alumnum rail
Thanks Agent 86 for the info. Jim
Free Tambour Rails Minno General Interior Topics 2 10-18-2010 02:44 PM
Window drip rails sealant reggiemon Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 02-21-2009 01:06 PM
Drape bottom rails walter1 Upholstery, Blinds, Walls & Interior Finishes 20 11-07-2007 07:34 AM
Blue Tape on rub rails cameront120 Clearcoat, Exterior Paint & Trim 15 07-17-2007 11:16 AM
Foam Insulation? Aluminum? Loose Curtain Rails? Revamp Goucho? 74Argosy24MH General Interior Topics 4 02-03-2005 08:39 PM
