Old 02-28-2007, 05:51 AM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Installing bare alum ceiling
My wife fell in love with the new interior shiny alum finish, I'm thinking about putting a 4' wide sheet(s) down the middle.
Also want to add the halogens or LED's in the ceiling.
Any suggestions on what to use?
Also is it possible to snake down a light switch by the main door thru the horzononal supports?
I'll remove the existing center ceiling to save weight etc.
What type alum and guage should I use?
'77 Sovereign Intl 31' CB
Old 02-28-2007, 06:50 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Bob, Halogens are brighter, but draw more power, and generate much more heat. LED's give less light, but consume MUCH less power, and are very cool in temperature.
You can snake a wire for a switch down, you can drill out the rivets on that particular panel to help get in there.
Old 02-28-2007, 07:25 AM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
For your center top skin that is going to be polished, If it were me, I woud use a thicker .040 aluminum because it will not distort as readily around the fasterers. Any distortion around fasteners will be very noticable on polished skin.
Old 03-05-2007, 09:55 AM   #4
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Because it is interior what grade aluminum would you suggest?
Alum. Skin Repair 74Tradewind Ribs, Skins & Rivets 12 10-31-2009 01:30 AM
Removing the body shell and installing new floor completely - any one done this? williamhenshall Repairing/Replacing Floor &/or Frame 11 03-13-2006 11:21 AM
Screen Replacement, Alum or Fibreglass? Road Ruler Windows & Screens 4 10-15-2002 08:44 AM
ceiling fan Cat Roof Vents, Skylights & Fans 0 10-06-2002 03:34 AM
Window sills (painted or bare aluminum)? Andy R Windows & Screens 2 06-04-2002 01:01 PM
