Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 03-16-2008, 07:17 AM   #1
GA Airstreamer Air_005
ALANSD's Avatar
Profile:  North , Georgia
Send a message via Yahoo to ALANSD
Installing a gaucho 80 model
I salvaged the gaucho from my 78 Sovereign which was totalled in a storm, and would like to install it in my 80 Excella which has none.
I have all the parts and know how to set it up as I removed it to do the flooring in the old trailer.
Question is this- the Sovereign had 2 metal plates on the wall that the gauchos arms screwed into. Can I install without those? Will the arms be secure if screwed inot the walls directly if I find a support frame?
Rallys twice a year..Lots of fun, food, and aluminum.
http://airstreampassion.blogspot.com/
My Music Ministry Site:
HTTP://ALANDAVIDSONGS.COM
Old 03-16-2008, 07:28 AM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
Alan, the reason those plates are there is to distribute the strain. If you only use the single attaching point, they fasteners will pull out of the wall. Our Sovereign has a similar issue, and plates were added to the existing hardware to keep the problem from recurring.
(No Longer at Inland RV)
Old 03-16-2008, 10:44 AM   #3
ALANSD's Avatar
Can I get the plates somewhere ...or use a substitute ?make my own, ?
Old 03-16-2008, 07:15 PM   #4
Well-Preserved
I'd just use squares of aluminum or stainless sheet. That's what's in ours, and it is holding up very well.
Old 03-17-2008, 06:04 AM   #5
87MH's Avatar
Profile:  1978 31' Sovereign
Katy , West Planet Houston, Texas
Images: 234
Not a compound curve.....
Originally Posted by ALANSD
...make my own, ?
Shouldn't be hard to do....
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 03-17-2008, 06:40 AM   #6
ALANSD's Avatar
Thanks guy, that is kind of what I was thinking, screw the mount plate into a support and then screw the arm plate into the mounted plate.
Old 03-24-2008, 02:42 PM   #7
ALANSD's Avatar
The gaucho is in and looks/ works well. I used aluminum cut to size and double in thickness where the plate goes into the wall.
Old 07-02-2008, 03:50 PM   #8
Profile:  1983 27' Excella
French Settlement , Louisiana
please send me some pictures
Could you please take some pictures and send to me I have had problems with my couch.I bought the trailer and I do not have the wall plates you were speaking of or know how they go.My couch back is loose and does not hold solid it feels like it will fall back.I will try to put some pictures of the couch and see it you can figure it out.I look in the manual and it does not show any wall plates.But my couch is not wright
housebg is offline   Reply With Quote
Old 07-02-2008, 05:04 PM   #9
Unhappy here are the pictures
Hope someone can tell me what is wrong
ID:	63092   Click image for larger version
ID:	63094   Click image for larger version
Our New Gaucho Silver Threads Upholstery, Blinds, Walls & Interior Finishes 7 11-11-2009 07:11 PM
Gaucho Silver Threads Upholstery, Blinds, Walls & Interior Finishes 22 04-01-2007 07:55 AM
Gaucho value LI Pets General Interior Topics 2 09-07-2006 07:29 PM
Gaucho DavidsonOverlander Parts Archive 3 03-04-2005 10:45 PM
New Gaucho John Greenlee General Interior Topics 3 05-02-2004 10:01 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
