03-17-2017, 07:41 AM
2014 23' International
Hurst
Increasing tension on Oceanair shades?
A couple of our Oceanair shades are just a bit 'lazy.' I'm wondering if the spring tension can be increased. Thanks.
Rob
03-17-2017, 07:59 AM
Granbury
Rob, not sure about your question...but I have another. Do you store your shades in the up or down position? Do you travel with the shades up or down?
Just curious...and wonder what others with these are doing.
Enjoyed the pictures of your Airstream...very nice! Saw what appears to be some custom features that look really sharp and functional.
03-17-2017, 08:03 AM
1955 22' Safari
Laredo
Some up some down
I usually travel with my front and rear blinds open so I can see out the back of the trailer. Most side ones stay down to keep the trailer cooler inside.
03-17-2017, 08:07 AM
2016 25' Flying Cloud
Jupiter
Rob
I haven't tried this, but based on the information here it sounds like it might be possible.
http://www.oceanair.co.uk/marine/new...-roller-shades
03-17-2017, 09:06 AM
Walnut Creek
That sounds like it's easy to adjust the spring tension on the roller shades. Thanks for asking. Nice to have info in memory if needed. Pat
03-17-2017, 12:31 PM
2009 34' Panamerica
2008 22' Safari
Metro Detroit Area & Metro Dallas Area
, Michigan & Texas
Adjusting the Tension
Make a call to Oceanair. They'll adjust similar to "old school" roller shades; however, you don't want to break the mechanism by over-torquing. The motherships MAY assist you over the telephone - IF - you are lucky and get the RIGHT customer focused service representative. My route was to call Oceanair. They talked me through the process.
03-17-2017, 01:54 PM
2017 25' International
Joliet
Rob
They sure can. You will need to remove the shade from the wall to start. 4 screws on each end. Those little round covers are a PITA to remove. Once it is removed from the wall you will see a screw that hold the ends on. I forget which side the spring is on. Remove the screw, DO NOT remove the end cap. Turn the end cap clockwise to tighten spring and reinstall set screw. Be careful not to over tighten the spring. Reinstall shade. If you can't get a proper adjustment on the spring a new one (spring) can be ordered from OceanAir.
03-19-2017, 05:32 PM
Hurst
Wow! Did that today on my two lazy-ish ones... nothing could be easier. Just one turn of the end cap restored great tension. Thanks to all who answered.
Rob
03-19-2017, 08:22 PM
Hurst
oops double post
05-02-2021, 10:05 AM
2015 30' International
Escondido
, CA
Use a eyeglass screwdriver, or a tiny thin stiff knife blade with a point or a metal dental pick that can split the seam and they will pop right out. Just make sure you watch them because that are round and can bounce and roll a great distance in a heartbeat. I had one that seated too deep to get a grip on it and I used the smallest drill bit I had to drill a tiny hole at the seam of the plug, then I was able to get my tiny eyeglass screwdriver in to pop it out. I just put that plug back in one of the lower holes that are covered when the the shades are up.
07-21-2023, 12:10 PM
Coast to Coast
2016 26' Flying Cloud
Winston Salem
Just finished on our 2016 FC and want to update the instructions for a cut and paste into your maintenance schedule. Thanks to Bel73 and others!
OCEANAIR ROLLER SHADES
TIGHTEN: remove the shade from the wall to start. 4 screws on each end. Those little round covers are a PITA to remove. Once it is removed from the wall you will see a screw FACING THE FRONT OF THE SHADE - Remove the very small set screw on the LEFT - DO NOT REMOVE THE END CAMP. Turn the end cap counter-clockwise to tighten spring. The shade will pull up and tighten. Be careful not to over tighten the spring. Reinstall set screw. Reinstall shade. If you can't get a proper adjustment on the spring a new one (spring) can be ordered from OceanAir.
