Old 08-02-2016, 07:16 AM   #85
1967 17' Caravel
The gelcoated fiberglass bathroom in my '67 Caravel is very yellow, but otherwise in excellent shape. I do my own paintwork on my car restoration projects, so I am going to treat the bath like a car body. Holes and cracks will be enlarged and then filled with thickened epoxy resin. After cleaning, I will use 220 grit sand paper to roughen the surface. Finally, I will wipe with a silicon/grease remover, tack cloth and prime with epoxy primer thinned to act as a sealer. Within the recoat window, I will spray the bath with Dupont Fulthane automotive paint custom match to the paint color to be used on the rest of the trailer. Just need to figure out how to get ventilation through the trailer without bringing in a lot of dust. Spray equipment will be HVLP.
David F is offline   Reply With Quote
Old 08-02-2016, 07:32 AM   #86
DilmoreFarms's Avatar
1984 31' Excella
brandon , Mississippi
If I am reading this thread correctly, under the vinyl wall paper, there is aluminium? So fi you strip the vinyl off you can polish the walls?
(ps very newbie)
DilmoreFarms is offline   Reply With Quote
Old 08-02-2016, 08:17 AM   #87
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I am saying it is going to get dirty, if I were you I would plan on doing a bit of debris removal via wet sanding and polishing on spots.
Consider a pressure/remote air mask for that confined location.
Gradiens super tenui glacie.
Old 08-02-2016, 09:56 AM   #88
1967 17' Caravel
For sure. I am thinking of placing a box fan in the front window and drawing air through the roof vent with filter media taped over the opening. Any dust that gets pulled in will turn to the front and hopefully stay out of the paint. Next problem is painting in 100* Texas heat. There is currently a small window unit installed in the rear/bathroom window (that is scheduled to be removed) that I want to have running while painting (otherwise, I will sweat into the paint). I plan to install filter media over the air inlet. Finally, running the fan and a/c I am somewhat concerned about causing an explosion. New respirator (suitable for isocyanates) should suffice.
Old 08-03-2016, 08:07 AM   #89
1972 31' Sovereign
Houston , Texas
David,
I would suggest shooting early in the morning to reduce heat issues.
Run the AC the night before to get it all cooled down.
When you are ready to start shooting, turn off the AC to avoid the explosive hazard.
You could put the box fan in the vent so it blows into the trailer, thus not being exposed to the paint fumes.
Also consider your lighting as an ignition source, especially if you use quartz light stands. The hot lights can also set off the paint fumes.
BayRat is offline   Reply With Quote
Old 08-03-2016, 08:54 AM   #90
1972 31' Sovereign
Houston , Texas
Painting vinyl covered aluminum
kidjedi
My research has found that there are paints for the vinyl siding on houses.
I am wondering if they would perform well on the vinyl covered interiors?
http://www.sherwin-williams.com/home...-vinyl-siding/
and
http://www.benjaminmoore.com/en-us/f...luminum-siding
Old 09-12-2016, 02:41 PM   #91
1973 23' Safari
1970 27' Overlander
Boerne , Texas
The Sign Lady - Great thread for painting. I plan on getting after my plastic end caps and bath tub very soon and plan on using krylon fusion paint. One question - did you use flat, satin, or gloss? Any recommendations for end caps and bath tub?
Thanks so much.
Greg
Greg1410 is offline   Reply With Quote
Old 04-18-2018, 10:37 AM   #92
my3sonsdad's Avatar
1975 Argosy 26
1979 30' Argosy
Vienna , VIRGINIA
Still a great thread! Does anyone have any updated product experiences to share on using the Krylon primer to expand the top coat color choices?
1975 Argosy 26
1979 Argosy 30
2015 Jeep GC Summit EcoDiesel w/Hensley
my3sonsdad is offline   Reply With Quote
Old 04-18-2018, 11:28 AM   #93
1972 25' Tradewind
1976 31' Excella 500
Denver , Colorado
After using more than 15 rattle cans to do the rear bedroom of a current build (took forever), I decided to try rolling on the paint for the kitchen/lounge. I used Valspar Bonding Primer and then Clark & Kensington Interior Satin Enamel. The rolled on paint/primer endures the scratch test WAY better than the spray cans. It just goes on so much thicker (while still looking smooth and even if you know your way around a paint roller).
25' 1972 Airstream Trade Wind Land Yacht
2006 Jeep Liberty CRD (diesel)
http://BeahmStream.com
kidjedi is offline   Reply With Quote
Old 04-18-2018, 07:09 PM   #94
my3sonsdad's Avatar
1975 Argosy 26
1979 30' Argosy
Vienna , VIRGINIA
C&K interior paint was also rolled on?
1975 Argosy 26
1979 Argosy 30
Old 04-18-2018, 07:28 PM   #95
1972 25' Tradewind
Denver , Colorado
Yep. This was over the interior skins, though, not the end caps, so some texture was desired. Had I been doing the smoother end caps, I would have taken the time to spray.
Is this the end of my end caps? unit13 Upholstery, Blinds, Walls & Interior Finishes 9 01-02-2017 10:42 AM
plastic end caps for horizontal blinds bpcaudill Upholstery, Blinds, Walls & Interior Finishes 6 09-26-2006 07:44 PM
Stripping the Interior End Caps--Am I Nuts? ironfem200 General Interior Topics 2 01-29-2006 04:07 PM
What kind of interior paint 1971 Overlander/End caps dingy riverdreamer Upholstery, Blinds, Walls & Interior Finishes 5 05-24-2004 09:36 AM
Styrene end caps for the aluminium bed extrusions chasgould Upholstery, Blinds, Walls & Interior Finishes 0 05-23-2004 04:23 PM
