Old 01-19-2015, 12:59 PM   #43
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Hi thefroghouse. With the 94 I am not sure if you have plastic end caps or fiberglass. I know for sure in my '72 argosy it is plastic so I used the Krylon Fusion so I could get that molecular bond that I know won't peel or chip, you could use still the fusion on fiberglass with proper surface prep like I described if that is what your trailer has....
Here is a cut and paste from the Krylon website
The revolutionary no-prep, superbond Fusion for Plastic® now makes painting plastic possible.
No sanding or priming required
Bonds easily to most plastics, PVC, resin and more
Fast dry; fully chip resistant after 7 days
Features EZ Touch 360® Dial Spray Tip
DRY TO TOUCH
15 minutes
DRY TO HANDLE
1 hour
FOR USE WITH
Wood, Metal, Wicker, Wrought Iron, Plastic, Hard Vinyl, Glass, Plaster, Ceramic, Paper, Paper Mache.
[COLOR="Blue"]Also if it is fiberglass you could also use regular enamel spray paint as well with proper surface prep
Here is site that gives instructions for painting fiberglass
How to Spray Paint Fiberglass | eHow
It is much the same as what I did
Being only a 94 it may also not really need a painting yet. If you have never used Mr. Clean magic erasers yet I would recommend buying some from your local grocery or hardware store and try a good thorough scrub with pine sol or a similar de-greasing cleaner. You will be amazed at how much gunk get lifted off with just those magic sponges. Post #23 in this thread shows the amazing difference I got cleaning my walls with various cleaners using them. You can clearly see how dirty the walls were by the lines left behind after I removed the tape. The one thing to note with the sponges is they only work when wet so bring a bucket of water in with you and rinse your sponge often. They also get break apart and smaller as you go, buy the heavy duty ones if you can find them. Post #5 shows a picture of a used Mr. Clean Magic eraser sponge with the 000 steel wool I used to revive my tambour doors you can see how it starts to fall apart. But man those things are amazing...
thesignlady is offline   Reply With Quote
Old 01-19-2015, 01:23 PM   #44
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Hi Jenniflow, I have rolled a lot of paint at work but never personally rolled paint anywhere in any of my AS collection. I know in my '63 Tradewind it has the old Zolatone finish and a previous owner rolled primer and regular house paint over it and that has failed horribly. It is coming off in major chunks and I will have a major job one day to strip it that will include having to gut the whole trailer so I don't accidentally splash stripper on the solid wood interior or floors. I of course don't know what surface prep that previous owner did...I can just see the layers where it has failed to know they did prime. It could simply have been a problem of improper surface prep and not researching what paint to use, but in the end it is a disaster that I will have to deal with.
Not saying it couldn't work, just pointing out the one experience I have with roll on paints over Zolatone.
Old 01-19-2015, 01:47 PM   #45
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Failed paint over Zolatone - one crazy tip that MIGHT work. An acquaintance of mine had her grandchildren over for a week long visit. They got into her garage and played with some cans of paint, and "decorated" her car. The whole family is in somewhat straitened means - so even Earl Scheib was out of the question. Of course she didn't find the mess until the day after so the paint was all dry. The newish latex loosened with hot water and dishwashing soap. Not 100% but maybe as muc as 90% - plastic razor blades and the edges of credit cards - and 4 or 5 ruined fingernails got off most of the rest. On the oil based paint - she laid down DUCT TAPE (sort of like waxing legs to remove hair) and let it sit over night then carefully peeled it back. Not saying the car looked like new when she was done but it was a beater before the kids started anyway. Dirt, wax and grease are the things that make for a poor bond between the surfaces. Whew.
Old 01-19-2015, 01:57 PM   #46
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
OH MY LORD... This is why children are created cute...so we don't kill them in instances like these ;-)
Old 01-19-2015, 02:00 PM   #47
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
On and hey...froghouse, I'm in Victoria BC, maybe we should organize our own Vancouver Island AS Rally one day ;-)
Old 01-19-2015, 02:11 PM   #48
Jenniflow's Avatar
1982 34' Limited
1986 34.5' Airstream 345
Sausalito , California
Send a message via Skype™ to Jenniflow
Thumbs up save us from children and the wrong paint
Geez! What a story! Did they think they were doing her a favor? What a nightmare!
Thanks signlady, again, so helpful. I am in the process of deciding how much I care about the interior right now, so no hurry, but I'm starting to hope that someone comes up with a rollable Fusion because I am super lazy!
Jenniflow is offline   Reply With Quote
Old 01-21-2015, 06:09 PM   #49
1994 30' Excella
Courtenay , British Columbia
Yes, Signlady in Victoria, we would love to do a rally in the future. Thanks for paint type; my husband and I just finished a project with Krylon paint. We ripped out the fuzzy wall stuff in the bedroom and replaced with tin panels and painted all the window frames, curtain rods and elec. cover plates. See attached. I will have to muster up the courage to do the front end cap. It has yellowed and I believe it is plastic./Users/dougmcgill/Pictures/iPhoto Library/Originals/2015/Jan 20, 2015/IMG_2292.JPG
thefroghouse is offline   Reply With Quote
Old 01-21-2015, 06:15 PM   #50
Jenniflow's Avatar
1982 34' Limited
Hey froghouse, I wasn't able to find your pics. Can you post the entire URL? Or am I missing something about how this works?
Thanks!
Old 02-09-2015, 09:33 AM   #51
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Thanks!
It looks like froghouse posted the path to some photos on her Mac, which isn't going to help you much. It happens when you use the link-photo button instead of the attach button for a file that's just on your local machine.
— David
Old 02-09-2015, 02:12 PM   #52
Jenniflow's Avatar
1982 34' Limited
Smile oh well
thanks DKX_SATX,
I guess I'll move on to the next thing. No worries!
Old 03-07-2015, 04:37 PM   #53
1975 25' Tradewind
Navarre , Florida
Thanks for the help
This thread is great! It helped me refresh my end cap, walls, and tambour doors. I used Krylon Fusion on the end cap and the tambour. An oil based enamel Kilz Primer/Stainblocker was used on the walls and a white Rustoleum oil based enamel was used for the top coat on the walls. Needless to say I am more than pleased with the results.
ID:	233803   Click image for larger version
Rsmied is offline   Reply With Quote
Old 03-07-2015, 05:13 PM   #54
Jenniflow's Avatar
1982 34' Limited
Thumbs up Inspiring!
You make it sound so easy! I'm still hoping to get to this before the end of the millenium ...
Old 03-08-2015, 12:45 AM   #55
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Wow Rsmied, it looks awesome. It sure makes a hell of a difference it making it feel more modern and airy inside to :-)
Old 03-08-2015, 08:33 AM   #56
1975 25' Tradewind
Navarre , Florida
Thanks! Now if only the exterior was as simple as the interior....
Is this the end of my end caps? unit13 Upholstery, Blinds, Walls & Interior Finishes 9 01-02-2017 11:42 AM
plastic end caps for horizontal blinds bpcaudill Upholstery, Blinds, Walls & Interior Finishes 6 09-26-2006 08:44 PM
Stripping the Interior End Caps--Am I Nuts? ironfem200 General Interior Topics 2 01-29-2006 05:07 PM
What kind of interior paint 1971 Overlander/End caps dingy riverdreamer Upholstery, Blinds, Walls & Interior Finishes 5 05-24-2004 10:36 AM
Styrene end caps for the aluminium bed extrusions chasgould Upholstery, Blinds, Walls & Interior Finishes 0 05-23-2004 05:23 PM
