06-05-2012, 11:12 AM
1972 27' Overlander
Cadiz
, Kentucky
Icky Vinyl Walls
Just started the resurrection of my 72 Overlander. I'm taking all the original out of inside, so if you wanna call dibs let me know, (take advantage and please don't scold me). So I have that yucky vinyl skin patched and repatched, super uneven, all over the interior. I was told that it's super hard to replace, but I'm rewiring and re-insulating anyway. What should I do about the walls once we're wired up and filled in? Should I put up another vinyl skin? Is there another material I should use that would bend around the dome and stretch? How hard is it to find that vinyl and/or put it up?
06-05-2012, 07:54 PM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
The vinyl is bonded to the aluminum "skins" In my 73 overlander I used 409 to scrub clean my walls. One of the nice things that I noticed was that it took away the sticky and it has not come back. Good luck.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
06-05-2012, 08:58 PM
1974 Argosy 26
Morrill
, Nebraska
I used " Simple Green" full strength spray mode. Rinsed with clean water. It looks almost new.
06-06-2012, 03:54 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
We used Krud Kutter to clean the accumulation off the wall, then after it dried gave it a light wash down with a diluted bleach and water solution. After that has completely dried you want to wax the walls with Furtura floor wax for the laminate floors (I think that is what is).
Aaron
WBCCI #XXXX AIR #2495
06-06-2012, 06:40 AM
Ahem, yasss ...kaff-kaff
1969 27' Overlander
Bloomington
, Indiana
I second the Krudkutter. It smells good, isn't toxic and cleans really well. It's amazing what it will remove, especially if you give it some time to soak. One of Betty's P.O.s was a smoker and the difference in the walls after cleaning is impressive. I used terry cloth rags and a fair amount of elbow grease with a a wipe down afterwards using a sponge and warm water. Hadn't thought to wax...good idea, Aaron!
Egad!
06-06-2012, 06:58 AM
1956 26' Cruiser Overlander
1970 23' Safari
Lambertville
, Michigan
I swear by Super Clean for washing the walls. Dirt, smoke and grease just melt away! You can find it in the automotive section at most store. The best way to get rid of the stickyness is to use a no wax floor polish like Mop and Glo or Future after cleaning.
06-06-2012, 08:34 AM
1977 25' Tradewind
Waskesiu Lake
, Saskatchewan
Spray-nine did an amazing job of cleaning the vinyl. Small scrub brush and an old tooth brush for getting in the nooks & crannies.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
06-06-2012, 01:56 PM
1981 31' Excella II
New Market
, Alabama
The only thing that seamed to work on mine was bleach spray. I have been hesitant to do this on the ceiling because of the danger of bleaching fabrics that I don't want bleached. I have used 409 and lyson wipes and those don't seem to work but the bleach did.
Perry
