08-19-2009, 04:25 PM
2004 31' Classic
lubbock
I have sticky ceiling
When I got The AS about 4 years ago the ceiling was sticky and I had to use some really extreme goof off to remove it...now its back...we havent cooked in the trailer but its back and it seems worse than before...I have noticed this in some other AS trailers and I'm wondering what causes this and how do I prevent it from coming back?
Confused in Texas
08-19-2009, 05:20 PM
1968 17' Caravel
Battle Ground
My advice is to quit touching the ceiling
I think it has to do with the plastic covering slowly deteriorating. There has been a great deal of discussion on this topic, and cleaners and processes to reduce the stickiness.
This one might get you started: http://www.airforums.com/forums/f46/...cky-51349.html
Stephanie
08-19-2009, 05:29 PM
1967 22' Safari
MILAN
Those black specks in the ceiling design are really flies that have become stuck up there! It's not so much the finger prints in the sticky stuff that is weird it is the foot prints! Ha Ha!!!! Use the search function on the blue tool bar above and search sticky walls and you will find lots of posts that should help you get the sticky off. I have used spray kitcken cleaner for wood cabinets with good results so far on my walls. Hope this helps Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
08-19-2009, 05:32 PM
1978 31' Sovereign
Charlottetown
, PEI
I have tried a load of cleaners because my trailer was sticky and smoky, by far the best product is Mean Green. That stuff means business.
------------------Melissa ------------------ WBCCI # 9099 PEI, Canada
08-19-2009, 06:40 PM
1968 30' Sovereign
1959 18' "Footer"
1954 22' Flying Cloud
Brussels
, Wisconsin
Awning Cleaner
The trick is awning cleaner. Worked on the 61, 68, 59, and most of all the 88. AWNING CLEANER!!!!!! thats the trick
I'm NOT an old man.............
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
08-19-2009, 06:49 PM
1964 17' Bambi II
Schererville
, Indiana
After you get the sticky gone, coat it with Future Floor Wax. It's acrylic & will keep the sticky from coming back. I can't take credit for this tip. Andy from Inland always gives this tip out & it works!
Becky
1964 Bambi II
1988 Avion 32S
08-19-2009, 07:21 PM
1978 28' Ambassador
Morada
Tried everything that was suggested here on Airforums, but I've found that POR-15 is the only thing that really works to clean the vinyl interior to my satisfaction, quickly and easily! Sure, some of the other stuff works, but not nearly as easy as with POR-15...
After cleaning and rinsing with plain water, when completely dried, a coat of Future Floor Wax as mentioned above will seal the surface and make it smooth and shiny again!
It was nice to have the old sticky ceiling collect all those bugs, just like your own built-in fly strip...
Ray & Pat; Morada, CA
08-19-2009, 08:06 PM
Power to the People !
1972 31' Sovereign
SAN DIMAS
Krud Kutter works great, but you have to rinse well. Then to seal and not have that sticky come back you need to use the future floor polish.
Mary
08-19-2009, 09:23 PM
Central
, Mississippi
Mary
I second the Krud Kutter. Mrs. HiHo did our '77 over 3 years ago and it's still fine. We never did use the floor polish.
I think the trick is to use the trailer at least once a month....
08-19-2009, 11:53 PM
1978 28' Ambassador
Morada
I'm sorry gang, I tried Krud Kutter also, and it doesn't do half the job that POR-15 does...KK took several applications to get the stuff off, for ours, at least...POR gets it in one application...learned about it here on Airforums!
You do need lots of ventilation, however, as POR is powerful stuff!
09-06-2009, 05:09 AM
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana
, Pennsylvania
Por 15
What is POR 15 and where do you get it? Thanks!
09-06-2009, 06:40 AM
Refurbished 89 Excella
1988 29' Excella
Sugar Valley
, Georgia
POR 15 has a lot of different solvents/acids..........which one?......Not only is this stuff hazardous to the technician/ME; but protecting the interior from spills seems to be a pain........what to do?.......thanks.....Dennis
Dennis & Susan
D&D Farms, Sugar Valley, Ga
Registered Boer goats
09-06-2009, 07:33 AM
1977 31' Sovereign
1989 34' Excella
Johnsburg
The sticky is caused by the liquid plasticizer which is used in the flexible PVC coating film. It degrades and becomes incompatible with the rest of the PVC formulation is kicked out of solution and ends up on the surface. You have to remove this sticky liquid and then seal the surface so it can not get out again.
09-06-2009, 09:56 AM
San Angelo
Tri-Sodium Phospate (TSP) works wonders. You can get it at any hardware store. Follow directions and you'll never have sticky ceilings again. I did mine four years ago, and it's still nice and smooth.
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
10-19-2009, 10:30 AM
1971 23' Safari
Marietta
, Georgia
This past weekend I used Krud Kutter to clean the walls in our Safari and it worked very well. I'll echo comments from other folks in that it has to be rinsed off really well!
I'm not sure if it was the wall paper adhesive or something else leeching out of the wallpaper in our 38 year old Safari, but after I sprayed KK on the walls (I worked on a 3'x3' section at a time) after a minute or so a tea colored substance started to form on the walls and it smelled really bad! It smelled similar to cleaning old rancid grease with a very powerful cleaner. I cleaned the walls twice and once they are fully dry and Krud Kutter odor has dissipated I'll seal the walls with Future wax.
This stuff definitely cleaned the walls well, but make sure you ventilate the trailer when you use it.
- David
1971 23' Airstream Safari - "Moe"
2017 Ford F350 4x4 6.7 CCLB - Silver/Black - "Max"
10-26-2009, 04:08 AM
1977 31' Sovereign
1989 34' Excella
Johnsburg
Dear PickerDD,
There was no conventional wallpaper adhesive used to produce the laminated aluminum sheeting used to produce the interior walls of your trailer and therefore there is no leeching of adhesive. As explained in post 13 above, there is a liquid plasicizer in the formulation of the PVC laminated material. Read post 13 above for details of the cause of the problem.
The interior wood panels do use a solvent based adhesive to laminate the PVC film to them. It breaks down over the years and the vinyl loses plasticizer and shrinks. This causes shear stress to occur in the bond and the vinyl frequently pulls loose from the plywood. The only solution to that is completely removing the vinyl film and then using contact adhesive to relaminate the panels. You may chose to buy new vinyl film at that time as it is difficult to remove and reinstall the vinyl without wrinkles.
10-26-2009, 05:55 AM
1971 23' Safari
Marietta
, Georgia
dwightdi,
Thanks for the clarification. Once I get all the walls clean (I plan to clean them again to remove any residual substance the first cleaning missed) I'll apply the wax Andy mentioned in a previous post to seal the walls.
- David
10-26-2009, 08:34 AM
Jupiter
*Note: For the Vinyl coated liners, not the end caps...
I tried three or five, maybe seven graffiti removers and other high strength cleansers and was as sickened by added overpowering fragrances as the original smellynast the trailer had when I got it, or the fact they didn't work, plus all of them left behind a film semi-bonded to the plastic especially visible as shiny spots & streaks when viewed from an angle.
This summer I went back over the trailer using Windex (off-brand) with 5~7% Acetone and 3~5% 2-butoxyethanol. An easy source for the butoxyethanol is 'dry erase board cleaner' found in office supply shops but I bought mine online in gallon quantity ($18) and an easy source for the Acetone is 100% pure Acetone fingernail polish remover found in large bottles in some discount stores.
A quote from Wikipedia " 2-butoxyethanol... ...provides cleaning power and the characteristic odor of Windex and other glass cleaners... ...is the main ingredient of many home, commercial, and industrial cleaning solutions; such as SimpleGreen..."
It takes many fresh paper towels to keep from redistributing the oily glaze this cleanser produces, and several wettings but gives a paper dry finish without any odor AFTER the surface dries and the soiled towels are removed from the trailer - it worked so good I thought I'd can it and sell it here - but the idea it might damage someones brand new trailer or remove the print off some obscure warning label stopped that idea quickly.
Anyway - the above mix chewed through 35-year-old grime under the galley and behind overhead storage racks when I stripped the interior this summer and just wanted to share it with y'all.
2-Butoxyethanol - Wikipedia, the free encyclopedia
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
10-26-2009, 10:24 AM
Corona
vinylclad interior metal
Once the vinylclad gets sticky, cleaning it is very time consuming.
Once it's clean, apply a couple of coats of "Future Acrylic Floor Polish" to it.
That will protect the walls from getting sticky again, as well as making them look great.
That polish is available at most any large grocery store.
This subject has been covered in depth, many times in the past on this Forums.
10-26-2009, 10:47 AM
1984 31' Airstream310
Ajo
If you're sensitive to harsh smells, Trader Joe sells a great product that we use.
It's called "Cedarwood & Sage Multi-purpose cleaner".
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Sticky brake
rwnash |
Brakes & Brake Controllers |
4 |
07-19-2007 09:42 AM |
sticky walls
arodriguez60 |
General Interior Topics |
18 |
07-24-2005 11:01 PM |
sticky?
eubank |
Forum Admin, News and Member Account Info |
2 |
01-18-2005 01:18 PM |
Sticky Door
gmlcjb |
Doors & Locks |
2 |
12-27-2003 06:42 PM |
sticky gunk
norbert |
Our Community |
7 |
08-17-2003 06:56 PM |
