Old 07-06-2011, 08:29 AM   #15
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
Cojer, It is hot a hell in the boatyard right now! Are you sure you're ready? It will cool off in late November! Boats are easy as nothing is square! Throw your square away. If you can make a bulkhead fit in an A/S you can do boats. Once again, hot as hell!
mhilley is offline   Reply With Quote
Old 07-06-2011, 08:38 AM   #16
CanoeStream's Avatar
St. Cloud , Minnesota
InsideOut decided to go with shellac for the most natural appearance on her amazing restoration of Birdy -- Which finish on vintage wood?
5 meter Langford Nahanni
Old 07-06-2011, 08:58 AM   #17
aftermath's Avatar
Spokane , Washington
I would vote for the Watco Danish Oil Clear finish if you want a natural finish that stands up well to heavy use. I have a couple of oak pieces that an industrial arts teacher friend of mine suggested I finish with Danish oil. It has been years since I have done it but the idea of a Danish oil finish goes something like this.
You apply the oil and wet sand the surface which will produce a bit of a muck on the top. You let this dry a bit and then rub it into the grain, hence the "hand rubbed" finish. The wood becomes very smooth to the touch and the process can be repeated as needed. Letting it dry before you add another coat of oil seals the finish.
I put this on an oak dining table that we used heavily for years. We never had an issue with spills or stains. If anything like that did happen you could just retreat that area by sanding, rubbing and applying a new coat of oil. I would occasionally, about every two years or so, wipe the surface with an oil soaked rag, let dry and then polish to keep it looking new. I live in the Pacific Northwest where the climate is rather arid and hot in the summer. We also get lots of rain and snow in the winter. If the oak starts to look like it is drying out, that is the time for adding some oil via a soaked cloth or rag.
I personally prefer this finish to a verathane or shellac for things that get heavy use. Repairs and touch ups are pretty easy.
aftermath is offline   Reply With Quote
Old 07-06-2011, 09:08 AM   #18
Yes, aftermath -- one problem with shellac is that it shows dings quite readily. It may yellow less than urethane finishes. Watco Danish Oil is an excellent alternative.
Old 07-06-2011, 10:08 AM   #19
1971 27' Overlander
2004 25' Safari
Jourdanton , Texas
A word of caution
Don't leave used rags in a pile. Some of the oil products are subject to spontaneous combustion . This is not a reason to avoid them. Just read the fine print and follow directions for disposal.
Prickly Pear is offline   Reply With Quote
Old 07-06-2011, 03:39 PM   #20
cojer's Avatar
1966 17' Caravel
salida , Colorado
damn i was bored today! lol... never did a bulkhead in an airstream either, but it doesn't scare me. not even a little...so i guess i'll wait for november to roll around.
cojer is offline   Reply With Quote
What is red toggle switch by door... AirheadOK General Repair Forum 15 06-17-2013 08:12 AM
Roses are Red...sort of jal4509 Fun & Games 18 10-12-2012 12:33 PM
Red Max Pro Taxman Land Yacht/Legacy Motorhomes 6 09-28-2011 05:55 PM
1960 wall wires blue black red white Lothlorian Lights - Interior & Exterior 2 04-02-2011 02:03 PM
Optima AGM Red Top start Battery Install John H. Classic Motorhomes 8 03-19-2011 09:17 PM
