Old 05-04-2013, 09:16 PM   #1
1998 25' Safari
Fergus , Ontario
How to remove mould on carpet walls
Can anyone tell me how to remove what I think is mould on my carpet walls of my 1998 Safari Airstream? I am assuming it is mould.
dnovosad is offline   Reply With Quote
Old 05-04-2013, 09:30 PM   #2
Goal15's Avatar
Dallas , Texas
Is it mold or the dreaded aluminum dust where rivets hit back of carpet? We have some on back wall near head of corner bed. Have wondered if carpet shampoo or woolite would work?
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 05-05-2013, 06:03 AM   #3
1998 25' Safari
Fergus , Ontario
Thanks for the reply, I will try a carpet shampoo in one spot and a mould remover in another. Because I also have it on the wall near the table. I just thought because it was close to the head where someone may sleep that it is from the moist air. If it is mould has anyone used anything that I can use? I am in Canada and can not get everything that is available in the United States. Thanks.
Old 05-05-2013, 06:07 AM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
You can use Clorox. We did in hand sprayer. Apply over several days. Dampen and let it wick in the solution. We used 1jigger of Clorox to a quart of water.
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-05-2013, 06:47 AM   #5
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
This worked well for us. It has been almost two years since and all is good.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 05-05-2013, 06:54 AM   #6
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Try Borax, in the laundry section. It is suppose to be better than bleach.
Dan
Old 05-05-2013, 07:30 AM   #7
1981 31' Excella II
New Market , Alabama
Resolve carpet cleaner.
Perry
Old 05-13-2013, 07:03 AM   #8
Alumination
2005 28' Safari
Hillsboro , Texas
Send a message via MSN to njoysrvin
Also use ammonia free foaming window cleaner and a microfiber cloth. Works great on carpet walls
njoysrvin is offline   Reply With Quote
Old 05-13-2013, 07:22 AM   #9
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
When I had a car flooded by a hurricane, while the carpet was still wet I added Pine Sol and let it soak in. Not only did it kill the mold, but it killed the mold smell, too.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-27-2013, 12:37 PM   #10
1998 25' Safari
Fergus , Ontario
Just an update: Solved the leaky window problem that caused the mold. Used a mold cleaner and then steam cleaned. All is excellent now! Thanks everyone for your help!
Old 05-12-2014, 03:51 PM   #11
PopHetzler
Emh142's Avatar
2003 34' Classic S/O
Troy , Ohio
I have the same problem. What brand mold cleaner and steam cleaner did you use? DH
Emh142 is offline   Reply With Quote
Old 05-13-2014, 05:04 AM   #12
Poyntelle , Pennsylvania
Mold and nasty dirt removal.
Bleach and some dish soap in some warm water.
catlady663 is offline   Reply With Quote
Old 05-13-2014, 06:15 AM   #13
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
We have used oxyclean on the "mouse fur" walls in our trailer to remove some stains from a previous water leak from one the the windows and it seemed to do the trick in that case.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
