Old 06-27-2010, 03:29 PM   #1
Splitrock's Avatar
Sioux Falls , South Dakota
How to remove drapes? and wall panel?
I want to take the drapes out but save the OEM tracks. How do I remove the old and install the new? How do I remove this upholstered wall panel?
I'm thinking I want new wall panels and new upholstery on the sofa to go with the new drapes and new floor.
This is the top curtain track.
This is the bottom track end. Sorry it's sorta hard to see.
Any tips appreciated, Thanks! Gary
Old 06-27-2010, 04:28 PM   #2
Kevin245's Avatar
Hey Gary,
On our top tracks we pulled the plastic end caps off and slide the tabs out. On the bottom we removed the end screw and did the same thing.
Ours doesn't have the wall pad so I can;t help you there but I'm sure others can advise.
BTW ours is a 76 Center bath also.
Kevin
Eleanor Roosevelt
Old 06-27-2010, 04:30 PM   #3
1960 24' Tradewind
Riverside , California
There is usually a screw in the track to keep the guides in, or remove the end cap and the guides will come out. The tracks in the bedroom sometimes need to be patially removed to allow the guides to slip out.
Greg
1960 Tradewind
2007 Denali 6.2
2005 ST 1300 ABS
2005 Chevrolet SSR 6.0 LS2
airstreamlosangeles.com
ZoomZoom is offline   Reply With Quote
Old 06-27-2010, 05:30 PM   #4
Splitrock's Avatar
Thanks for the replies. I'll have a go at it.
I got the sofa frame out and that was holding the wall panel on the bottom. The top of the panel uses a real hi-tech fastening system . . . 5 pan head screws painted brown.
Now I found some soft floor by the entry door after I removed the tray storage and folding finger pinch table.
Anybody got a quick link to a floorboard replacement thread?
Thanks, Gary
electric wall panel heater funkill Furnaces, Heaters, Fireplaces & Air Conditioning 17 01-01-2011 09:48 AM
Question - Remove wood panel flashgrbiv Upholstery, Blinds, Walls & Interior Finishes 6 01-30-2008 12:39 PM
wall panel sources wannaroam General Interior Topics 1 09-16-2007 06:46 AM
how to remove bed "wall pads"? charlie tuna Cabinets, Counter Tops & Furnishings 12 02-17-2007 05:52 PM
What kind of paint for a louver cover for a wall panel heater cindy General Interior Topics 1 09-19-2002 09:38 AM
