Old 09-13-2014, 08:18 PM   #1
Anchorage , Alaska
How to refurbish plastic interior wheel well covers ?
I am working on a 1963 Bambi. Spoke with VTS, and apparently the interior plastic wheel well covers are no longer available.
When I took them off, I did not look close, but thought they were fiberglass, and no big deal to resin and lay some cloth over them. But now that it is time to put them back in, it seems they are some kind of now brittle plastic.
Is there a way to refurbish these ?
How about just clean them up ? I've tried citris cleaner, paint thinner, and MEK. With MEK kind of made some progress, but slow enough, I may run out of brain cells before the job is done.
Aktundra is offline   Reply With Quote
Old 09-13-2014, 08:42 PM   #2
reinergirl's Avatar
Hollis , New Hampshire
I have a 63 overlander and mine were fiberglass, what does the underside look like? Mine are fiberglass with red threads.
I think West Systems has a patching product for plastics.
If they are fiberglass, it looks like you can strip them with Citrastrip. I've had a piece of mine sitting in Citrastrip for 2 days with no ill effects that I can see
reinergirl is offline   Reply With Quote
Old 09-13-2014, 08:58 PM   #3
DFlores's Avatar
1968 22' Safari
We refurbished our interior wheel wells utilizing a plastic mesh drywall tape and PVC adhesive. We apply adhesive in area of crack just like epoxy resin, then place mesh drywall tape, then more PVC adhesive. Two layers worked for us. We worked only on backside, because we were not sure it would sand like fiberglass. Give it time to dry and it firms up nicely.
Sent from my iPhone
David & Diane
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 09-13-2014, 11:52 PM   #4
Anchorage , Alaska
Can't tell much from this pic of the insides. One wheel well still has the insulation batting in it. (Still trying to think of a way to finish removing the remnants of the insulation from the one I started)
Both still have the AL flashing to attach to the interior skins.
Old 09-14-2014, 09:33 AM   #5
DFlores's Avatar
1968 22' Safari
Try a wire brush to remove left over insulation, then drill out rivets with 1/8" drill bit
Sent from my iPhone
David & Diane
DFlores
David & Diana
Old 09-14-2014, 10:06 AM   #6
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
The '65 I'm restoring has galvanized metal wheel well's that had
a brittle plastic cover interior side. ???
Del Gurney is offline   Reply With Quote
Old 09-14-2014, 05:34 PM   #7
Anchorage , Alaska
Del
I think my '63 is the same. Actual wheel wells are galvanized, these are just an interior cover.
They are probably ment to be nside cabinentry, however they seem too flimsy to support any weight under any circumstances. Wondering if it's possible to resin/fiberglass directly on the old plastic to give me something a little stiffer and paintable ?
Old 09-14-2014, 06:42 PM   #8
reinergirl's Avatar
Mine had aluminum tops that were riveted on. While I wouldn't call them sturdy, it's an alternative to fiberglassing them, and probably cheaper. To give any real advice we need to see what's under all that old pink fiberglass .
Old 09-14-2014, 06:59 PM   #9
DFlores's Avatar
1968 22' Safari
Wax them up and spray some resin over them to create new wheel wells, they only are meant to hold insulation against exterior wheel wells. Just like making speaker boxes.
Sent from my iPhone
David & Diane
DFlores
David & Diana
Old 09-14-2014, 10:15 PM   #10
Anchorage , Alaska
Very interesting idea to just fab a new set out of aluminum, and splash some kind of auto underbody sealant around the inside.
I can probably salvage enough decent material out of the old belly pan.
Old 03-28-2015, 10:46 PM   #11
zonacpa's Avatar
Tucson , Arizona
Name:	ImageUploadedByAirstream Forums1427604370.687562.jpg
ID:	235107Click image for larger version
Name:	ImageUploadedByAirstream Forums1427604408.135051.jpg
zonacpa is offline   Reply With Quote
Old 03-28-2015, 10:48 PM   #12
zonacpa's Avatar
Tucson , Arizona
Originally Posted by zonacpa View Post
Attachment 235107Attachment 235108
Name:	ImageUploadedByAirstream Forums1427604440.949874.jpg
ID:	235109Click image for larger version
Name:	ImageUploadedByAirstream Forums1427604455.966992.jpg
I made mine out of al.
Old 02-06-2017, 08:35 PM   #13
1972 23' Safari
Middletown , Rhode Island
Reviving old thread
Anyone make the interior wheel wells out of plywood?
Mx468 is offline   Reply With Quote
Well, well, well...you'll never guess what followed us home today! InsideOut Vintage Kin 85 11-28-2017 07:58 PM
Wheel well plastic jcessna Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 4 12-12-2011 08:56 PM
Well, Well, Well........ Jim & Susan Off Topic Forum 54 06-12-2005 12:46 PM
