Old 07-21-2010, 07:52 PM   #1
Whitefawn
whitefawn's Avatar
1978 Argosy 24
Scottsville , Virginia
How to clean and paint wood walls AFTER wallpaper removel
This is a new variation of an old theme-- The PO of our new 1978 Argosy removed a lot of the warped or rippling vinyl wallpaper, which left sticky, bare wood walls. Now I would like to clean and paint those walls- and I am looking for suggestions how to clean the sticky wood and then use whatever might work to paint those surfaces. Any success stories dealing with that situation?
Kathy
whitefawn is offline   Reply With Quote
Old 07-21-2010, 08:21 PM   #2
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Kathy, I had the same problem in our "78" Ambassador. The vinyl had lifted in several places and needed removed. Once I got the vinyl off, I ran a palm sander over it and then covered it with several coats of BIN primer. I had the primer toned to match the final paint selection. Once primed I put on two coats of latex paint. Looks pretty good if I may say so. Good luck with your project!
TAC PA-5
Roadrunner is offline   Reply With Quote
Old 07-21-2010, 08:52 PM   #3
Whitefawn
whitefawn's Avatar
1978 Argosy 24
Thanks. It sounds like work! I need to decide if I want to remove ALL of the wallpaper, the stuff that is still intact, or just deal with the exposed sticky wood for now. This trailer needs lots of TLC...
Kathy
How Do I Clean The Upholstered Walls? Chaplain Kent Upholstery, Blinds, Walls & Interior Finishes 5 05-20-2009 09:26 AM
wood walls in an A/S? Dave Cole Upholstery, Blinds, Walls & Interior Finishes 26 03-10-2008 12:35 PM
Wood Walls donf General Interior Topics 2 05-31-2006 07:12 AM
Vinal wood walls tinman7 Upholstery, Blinds, Walls & Interior Finishes 4 02-27-2004 11:45 AM
Removing vinyl wallpaper/paint GAS Upholstery, Blinds, Walls & Interior Finishes 19 07-21-2003 01:35 PM
