Old 06-20-2018, 10:11 PM   #1
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
How do I fill holes in my old interior vinyl clad skin
So, we're planning to reuse and paint our vinyl clad interior skin once we reinstall it. One problem that I foresee is all of the old screw and rivet holes that will be visible after changes in window treatments, cabinet and fixture placement, etc. If these were drywall or plaster or even wood walls I'd know exactly what to do, but aluminum? And these walls will be bouncing around to top it off. So, epoxy? I'm looking for the solutions others have come up with. As I mentioned we intend to prime and paint the interior skin.
P.s. These holes are random and numerous. Filling them with more rivets would look terrible.
Pete
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500 Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 06-20-2018, 10:38 PM   #2
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
I built a aluminum endcap for ours and stripped the front walls to bare aluminum, since I removed our radio I also wanted the speakers gone so I could have patched but instead I made new skins for those areas. I had bought a roll from Aircraft spruce delivered to do the endcap so I did the same for the new panels.
I think a few rivets to fill holes is not the worst thing.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 06-20-2018, 10:56 PM   #3
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
I had the same issue. I used all purpose bondo. Worked awesome! Primed and painted. You can even see the old holes. Click image for larger version
ID:	314677 I got the suggestion from many others on the forum. Work in small batches and it's sandable in 15 minutes. It's a permanent fix.
Matt
rugjenkins is offline   Reply With Quote
Old 06-20-2018, 10:58 PM   #4
rugjenkins's Avatar
1975 Argosy 28
Bondo after the skins are reinstalled. Caulk all the seams then paint. It will be almost perfect
Matt
Old 06-21-2018, 07:47 AM   #5
Re-Pete's Avatar
1992 29' Excella
Thanks for your suggestions and encouragement Alan,
I wish it were just a few holes. It may come to some replacement, but hoping to avoid that at this point. Since my plan is to keep the skins as is (with vinyl cladding) a new unclad piece may stand out even worse.
Pete
Originally Posted by rugjenkins View Post
I had the same issue. I used all purpose bondo. Worked awesome! Primed and painted. You can even see the old holes. Attachment 314677 I got the suggestion from many others on the forum. Work in small batches and it's sandable in 15 minutes. It's a permanent fix.
Thanks for this suggestion Matt,
I've never worked with Bondo, so it hadn't occurred to me. Now it seems like the obvious choice! I appreciate your help and encouragement.
BTW, what type of primer and paint did you end up using?
Pete
Virginia Beach, VA
Old 06-21-2018, 11:23 AM   #6
rugjenkins's Avatar
1975 Argosy 28
I used this for primer:Click image for larger version
I then used a good interior latex.
Matt
Old 06-21-2018, 07:34 PM   #7
Re-Pete's Avatar
1992 29' Excella
I used this for primer:Attachment 314710
Thanks Matt. Much appreciated.
Pete
Virginia Beach, VA
Looking for Vinyl Clad Aluminum Interior Skins Eugene General Interior Topics 4 05-13-2014 11:23 PM
Best way to remove Vinyl from interior vinyl clad Eric H General Interior Topics 11 10-21-2013 12:32 PM
New toilet holes don't match old holes RichHog Sinks, Showers & Toilets 8 03-15-2009 07:36 PM
Red Mold on Vinyl clad aluminum interior stoop Upholstery, Blinds, Walls & Interior Finishes 2 07-20-2004 02:27 PM
Vinyl clad aluminum aviontt Ribs, Skins & Rivets 1 09-26-2003 09:00 AM
