Old 05-19-2009, 03:31 PM   #1
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
How Do I Clean The Upholstered Walls?
I have a 1994 Excella 1000 with white upholstered walls which need a good cleaning especially after setting the ceiling on fire. (see thread on ceiling sag) I have tried carpet cleaners, and an array of other cleaners all the way up to Krud Buster with no success. What is the secret to getting these walls clean?
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 05-19-2009, 06:15 PM   #2
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
Folex
My brother is the super. of maintenance at a senior citizen complex where they experience all kinds of terrible and old spots and stains. He gave me a product that they use called Folex. I pick it up at Lowe's. Don't know if it will help with smoke damage but it might...worth a try. It does take out RED Koolaid. For smoke odors you can use ODOBan.
Lou
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 05-19-2009, 06:19 PM   #3
redstart's Avatar
1998 34' Limited
ont , Ontario
do a google search on mouse fur - that's what it is often called.
"mouse fur" site:www.airforums.com - Google Search
redstart is offline   Reply With Quote
Old 05-19-2009, 08:39 PM   #4
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
IMHO... nothing. My mouse fur had already been vacuumed to death and everything aluminum was already pulled though and now visible. There was someone that thought about spraying it with a fabric paint. I took on the other approach and replaced it all with cream hull liner. It looks to be exactly what airstream used and its installed with 3m sprayglue. I took everything out and used the old stuff as a pattern. If you tackle a job like this you think you need your head examined for taking it on but its not that bad once you get rolling. Good luck!
Vin
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 05-20-2009, 08:03 AM   #5
1994 30' Excella
I have the smoke and fire part cleaned up as the fire was contained to the ceiling. What I am trying to remove is the years of dirt found on these walls. The PO had removed the drapes which is OK but left the hardware. I took off the hardware and found black, not mold or mildew stains all around the area. Someone else must have this upholstered wall and found a way to clean it. after replacing the ceiling I am not about to replace the walls.
Chaplain Kent
Old 05-20-2009, 08:26 AM   #6
moderator
Airslide's Avatar
Wilton , California
Images: 50
I dont blame you.. Here is a link that was started about this. http://www.airforums.com/forums/f46/...lls-48767.html
Good luck
Vinnie
Product(s) to clean interior walls? ARMYOFME 2002 - 2005 International 1 04-26-2009 01:05 PM
Why won't it clean up??? augier Cleaning, Stripping & Polishing 11 01-21-2009 07:50 AM
upholstered header above front windows in Argosy campman Upholstery, Blinds, Walls & Interior Finishes 0 10-15-2008 10:22 PM
UPHOLSTERED WALLS? has anyone done it tin can luv Interior Restoration Forum 30 02-06-2004 05:23 PM
getting behind the walls... Chuck General Interior Topics 14 07-11-2002 12:20 PM
