Old 08-06-2007, 11:07 PM   #1
LJH
LJH's Avatar
1985 27' Sovereign
Defiance , Ohio
Holey Walls, Batman!
We are redoing an 85 Sovereign 27. It has many holes in the interreor walls, things were hung on hooks, old no longer used rivet and screw holes etc. How does one go about paching them be fore refinishing?
LJH is offline   Reply With Quote
Old 08-06-2007, 11:15 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
The simplest thing to do may be to put a rivet in each hole and round it over. it will come close to matching the existing rivets and look intentional. You could even paint the rivet heads to match any existing ones.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 08-06-2007, 11:17 PM   #3
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
What do you plan to refinish with?
Holes in wood can be filled with fillers that are colored. Find one that matches closely.
Aluminum holes are more of a problem. You can put pop rivets in them, but if there are that many it will look bad. Maybe use the fabric that modern trailers sometimes have, cover over the whole mess. Good luck,
Dave
Fyrzowt is offline   Reply With Quote
sticky interior walls sovereign Upholstery, Blinds, Walls & Interior Finishes 64 08-14-2009 10:18 AM
Zolatone walls Rob Upholstery, Blinds, Walls & Interior Finishes 19 08-05-2009 06:54 PM
Dull walls and yellow plastic ends 74SovereignInt. Upholstery, Blinds, Walls & Interior Finishes 35 10-15-2004 12:57 AM
Shower walls, what to do? myboyburt General Interior Topics 1 04-16-2004 03:54 PM
getting behind the walls... Chuck General Interior Topics 14 07-11-2002 12:20 PM
