Old 10-04-2010, 01:24 AM   #1
1968 20' Globetrotter
1957 22' Flying Cloud
Tracy , California
holes in interior walls
I have several holes in the roof of my interior vinyl wall from an air conditioner put in by the prior owner. I would like to patch the holes, but I dont know how or what to use. Can somebody please help. Thanks.
Rickman4 is offline   Reply With Quote
Old 10-04-2010, 07:46 AM   #2
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
If it's vinyl over aluminum, you could rivet another panel of color-matched aluminum over it. If vinyl over wood, just screw another sheet of matching wood over the hole.
Worst case, do like apartment dwellers and hang a picture over it.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 10-04-2010, 09:01 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I'd install an aluminum patch and then install a "hull liner" headliner. Its a good looking heavy, cleanable, material used on Airstreams and other high end RVs and boats. Use the best adhesive and it won't fall. Do not use a foam back liner as a substitute material...it will fail.
Old 10-06-2010, 03:06 AM   #4
rivet an aluminum patch over the hole, making sure you get really tight to the skin. next time you re paint your AS use a thick latex paint and a textured roller
Chizlam is offline   Reply With Quote
Old 12-11-2010, 08:00 AM   #5
1975 29' Ambassador
denman is , b.c.
Do you think this would work on the curved headliner over the front window? I have a crack in mine and need something to cover it as I don't want to even try to get at the back of it.
kooshka is offline   Reply With Quote
Old 12-11-2010, 08:11 AM   #6
1975 29' Ambassador
denman is , b.c.
Question Hull liner??
Do you think this would work on the curved headliner over the front window? I have a crack in mine and need something to cover it as I don't want to even try to get at the back of it. Also, I am not familiar with this "hull liner". Where do you purchase it?
Filling holes in the walls jolomo Upholstery, Blinds, Walls & Interior Finishes 2 01-23-2009 08:51 PM
Interior walls-What to plug holes with?? rogerdodger Upholstery, Blinds, Walls & Interior Finishes 17 06-12-2008 06:06 AM
Interior Walls tique79 Upholstery, Blinds, Walls & Interior Finishes 1 06-02-2007 04:16 PM
interior walls happier General Interior Topics 7 07-02-2005 02:04 AM
Interior walls dmadam Upholstery, Blinds, Walls & Interior Finishes 0 10-27-2004 06:59 PM
