Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 11-11-2007, 12:23 AM   #1
Idaho Ken
Idaho Ken's Avatar
Profile:  1977 27' Overlander
Lava Hot Springs , Idaho
Help on plastic edge trim inserts
I am looking for plastic trim inserts that go in aluminum extrusion trim. I am working on the galley and bath in a 77 overlander. Readily available RV trim insert sold as 1 inch really isn't. It's to narrow and soft to fit the Airstream trim extrusion. I have looked at the links provided in this forum but can't find what I am looking for. Here's a couple of pix of what I am trying to find. Thanks for any help.
Idaho Ken is offline   Reply With Quote
Old 11-11-2007, 06:02 AM   #2
juel
juel's Avatar
Profile:  1978 Argosy 24
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Try searching these sites: Rockler.com and Brunner Enterprises.
juel is offline   Reply With Quote
Old 11-11-2007, 06:13 AM   #3
PizzaChop
PizzaChop's Avatar
Profile:  1973 31' Sovereign
Danielsville , Georgia
Images: 197
Strips of linoleum work well and will match the floor if you replace it.
I've also heard of others using plastic from venetian (sp?) blinds.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 11-11-2007, 09:45 AM   #4
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
I was unable to find this trim a few years ago. I ended up using aluminum colored heavy tape from a sign shop, cut to size and inserted into the groove. I did not remove the adhesive backing cover, but rather used it as it came. It looked pretty good, and as I recall, came in many different colors. My bath hed just been refinished in a very clean white color, so the silver tape made it look even cleaner. The old brittle yellowed insert just did not make it, visually.
Uwe
Old 11-11-2007, 09:53 AM   #5
Ganglin
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
You might try calling Airstream and getting a hold of the parts department. Send them a photo of what you need via email. It will be hit or miss with them as they have a variety of trims in storage - none that would fit my 71 by the way - but you could get lucky.
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 11-11-2007, 12:05 PM   #6
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Attachment 49149
Attachment 49150
That insert is readily available from a parts stocking dealer.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 11-11-2007, 01:00 PM   #7
PizzaChop
PizzaChop's Avatar
Images: 197
Uwe,
I'd like to see a picture of that.
Ron Kaes
Psalm 112
www.paparonnis.com
Old 11-11-2007, 01:16 PM   #8
uwe
418
uwe's Avatar
Images: 40
It wasn't when I needed it in 2004. I asked everywhere.
Uwe
Old 11-11-2007, 01:17 PM   #9
uwe
418
uwe's Avatar
Images: 40
Originally Posted by PizzaChop
Uwe,
Ron, I sold that particular trailer a while back, and did not take pics of the bath remodel. It was a wet bath, very small and awkward to take pictures of.
Uwe
plastic extrustion for Aluminum Panel Edge on Ceiling macbob1240 Interior Restoration Forum 3 08-29-2007 08:54 AM
stripe and trim inserts ALANSD Clearcoat, Exterior Paint & Trim 13 08-01-2006 11:05 AM
Plastic trim Cochese General Interior Topics 1 06-17-2006 10:21 PM
Attaching and Bending Edge Trim PhilMateo Cabinets, Counter Tops & Furnishings 1 03-27-2006 07:56 AM
seal the bottom edge trim pieces? cindy Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 10-23-2002 09:18 AM
