Old 11-11-2007, 12:23 AM   #1
Idaho Ken's Avatar
1977 27' Overlander
Lava Hot Springs , Idaho
Help on plastic edge trim inserts
I am looking for plastic trim inserts that go in aluminum extrusion trim. I am working on the galley and bath in a 77 overlander. Readily available RV trim insert sold as 1 inch really isn't. It's to narrow and soft to fit the Airstream trim extrusion. I have looked at the links provided in this forum but can't find what I am looking for. Here's a couple of pix of what I am trying to find. Thanks for any help.
Idaho Ken is offline   Reply With Quote
Old 11-11-2007, 06:02 AM   #2
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Try searching these sites: Rockler.com and Brunner Enterprises.
juel is offline   Reply With Quote
Old 11-11-2007, 06:13 AM   #3
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
Strips of linoleum work well and will match the floor if you replace it.
I've also heard of others using plastic from venetian (sp?) blinds.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 11-11-2007, 09:45 AM   #4
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I was unable to find this trim a few years ago. I ended up using aluminum colored heavy tape from a sign shop, cut to size and inserted into the groove. I did not remove the adhesive backing cover, but rather used it as it came. It looked pretty good, and as I recall, came in many different colors. My bath hed just been refinished in a very clean white color, so the silver tape made it look even cleaner. The old brittle yellowed insert just did not make it, visually.
Uwe
www.area63productions.com
Old 11-11-2007, 09:53 AM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
You might try calling Airstream and getting a hold of the parts department. Send them a photo of what you need via email. It will be hit or miss with them as they have a variety of trims in storage - none that would fit my 71 by the way - but you could get lucky.
Old 11-11-2007, 12:05 PM   #6
Attachment 49149
Attachment 49150
That insert is readily available from a parts stocking dealer.
Old 11-11-2007, 01:00 PM   #7
PizzaChop's Avatar
1973 31' Sovereign
Images: 202
Uwe,
I'd like to see a picture of that.
Ron Kaes
Psalm 112
www.paparonnis.com
Old 11-11-2007, 01:16 PM   #8
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
It wasn't when I needed it in 2004. I asked everywhere.
Uwe
Old 11-11-2007, 01:17 PM   #9
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Originally Posted by PizzaChop
Uwe,
Ron, I sold that particular trailer a while back, and did not take pics of the bath remodel. It was a wet bath, very small and awkward to take pictures of.
Uwe
Old 06-10-2011, 12:34 PM   #10
shebeen's Avatar
1975 29' Ambassador
1995 31' Land Yacht LE
Southwest , New Hampshire
Resurrecting this thread from 2007.
Andy, by "parts stocking dealer" do you mean the factory?
Looking for a sort of 'burnt orange' color for a 1975 International Overlander.
Any new info would be greatly appreciated......thanks all.
shebeen is offline   Reply With Quote
Old 06-10-2011, 12:38 PM   #11
A "parts stocking" dealer is a dealer who normally stocks many parts for telephone or on line ordering by Airstream owners.
Unfortunately many dealers do not stck anything but a very few repair parts.
Old 06-10-2011, 12:40 PM   #12
Ottawa , ON
Be sure to ask any "parts stocking dealer" before you buy it if it is a good, exact, proper fit.
I bought a bunch of it from one, and after I bought it and complained that it would not fit, I was told that it needed "a bit of sanding" to go in.
I still have it, uninstalled. I sanded till my hands were sore, no go.
Old 06-10-2011, 05:32 PM   #13
shebeen's Avatar
1975 29' Ambassador
Thanks guys.....trying to keep it somewhat 'original'.
Dyed the curtains a similar color so I'm sort of locked-in with the burnt orange.
If anybody told me 20 years ago that I'd be dying curtains I'd have told them they had a SCREW LOOSE!
How times change.
Old 06-10-2011, 06:03 PM   #14
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
How times change.
I would think the screw was loose from keeping the burnt orange color scheme...
When I did the teardown of my 1975 I found one scrap of the original orange shag carpet in a closet. I am considering having it framed and mounted.
Aaron
WBCCI #XXXX AIR #2495
plastic extrusion for Aluminum Panel Edge on Ceiling macbob1240 Interior Restoration Forum 3 08-29-2007 08:54 AM
stripe and trim inserts ALANSD Clearcoat, Exterior Paint & Trim 13 08-01-2006 11:05 AM
Plastic trim Cochese General Interior Topics 1 06-17-2006 10:21 PM
Attaching and Bending Edge Trim PhilMateo Cabinets, Counter Tops & Furnishings 1 03-27-2006 07:56 AM
seal the bottom edge trim pieces? cindy Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 10-23-2002 09:18 AM
