Old 07-08-2010, 08:22 PM   #1
1976 Argosy 24
Excelsior , Minnesota
Help finding Interior Molding
I am in need of about 12 feet of the interior molding that has the white plastic nose insert in it. It is used around the headliner and in the bath in various models. I need it to hold the bottom of my headliner in place. Andy at Inland said AS no longer carries it. Is there anyone parting out a trailer with it, or does anyone know of where to find it? The white insert is called white plastic nose insert and it is available from several places. I need the molding that it goes in. Any ideas would be appreciated.
Steve Finch
Steve Finch is offline   Reply With Quote
Old 07-09-2010, 04:48 AM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
A few places you might try - there are more out there:
G 343 - Extruded Aluminum Edge Treatments - Aluminum angle, Aluminum tube, Aluminum extrusions, Anodized aluminum, Aluminum pipe, Aluminum channel, Extruded Aluminum angle, brunner enterprises, Aluminum bar, aluminum rod, aluminum edging, aluminum tu=
Interstate Metal Fabricators, Inc.
Old 04-24-2011, 08:09 PM   #3
stream lady's Avatar
1975 Argosy 20
new iberia , Louisiana
plastic nose insert
I was able to order it from out of door mark to replace the one in our 77 overlander,but it don't fit.It started to go in good but then stop.Has anyone else had this problem?
stream lady is offline   Reply With Quote
Old 06-25-2011, 03:19 PM   #4
Airline's Avatar
1972 29' Ambassador
grants pass , Oregon
bathroom moulding
I need this same moulding as well.
Airline is offline   Reply With Quote
Old 06-25-2011, 06:20 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Make your own
The molding strip is 1 1/16" wide. Most of the stuff that is available is 1" wide. I cut mine from the scrap left after installing new vinyl flooring in the bath. It is easily cut with a pair of scissors. Oops! I posted this and then realized that you are looking for the aluminum piece as well. OH WELL.
ID:	133270   Click image for larger version
Old 06-26-2011, 08:31 AM   #6
1975 Argosy 20
Bathroom insert
Hi Steve, We was able to use the insert from out of door mark but had to trim as we went it was hard.I'm still thinking of what we will use in the bathroom when we get ready to paint and finish it up.Lot of ideas out their. Good luck SARAH
Old 07-01-2012, 09:31 AM   #7
sunny 75
sunny75's Avatar
1975 27' Overlander
selah , Washington
bathroom trim replacement
After reading everyones suggestions, I came up with another solution for replacing the trim. Ours was missing a few pieces, but I liked the "yellowed" color and didn't want to replace all of it. We had removed the blue rub rail trim from the outside of the trailer, which was exactly the right size. We painted it with Krylon Fusion in "buttercream". Perfect match! It popped right into the metal trim and no one will know the difference between the new and old.
Name:	sunny bath 2.jpg
sunny75 is offline   Reply With Quote
molding for a 92 300LE prayerwheel General Motorhome Topics 1 10-30-2009 08:05 PM
Molding in shower Spin All Argosy Trailers 22 04-28-2008 03:17 AM
Window Molding? lwebb Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 05-05-2006 11:36 AM
Concealment Molding uwe General Interior Topics 24 04-13-2004 11:36 AM
'86 345 AS MH Interior Molding Jim Tyrney Airstream Motorhome Forums 2 03-09-2004 06:41 AM
