Old 07-10-2011, 12:54 PM   #43
Elgin , Texas
Images: 164
Originally Posted by Tinkler2002
I was wondering about just cutting out old vinyl and removing old adhesive. Could I just leave ceiling bare metal would the finish look ok if I did this I could experiment in bedroom due to being smaller area. Any suggestions on this thanks in advance!
Hi Tinkler,
I still have the areas of galley and bath with the vinyl and adhesive removed. It actually looks okay, but there may be differences in what people find when they remove their own vinyl and adhesive. I don't think Airstream expected anyone would be doing that, and so might use sections of skin that may have scratches or holes, since they knew they were covering it up anyway. In my case, I have the odd scratch here and there, as well as a few holes where they missed a rib when drilling for rivets. I took care of those by just filling them with a rivet.
Things like this are why I cringe a little when folks talk of re-fastening their headliners with screws... Sort of limits your options should one ever wish to go with the bare ceiling, IMO. ;-)
bake315 is offline   Reply With Quote
Old 07-11-2011, 04:31 AM   #44
Grove city , Ohio
Yea also screws scare me with electrical wiring running in ceiling!
Tinkler2002 is offline   Reply With Quote
Old 09-08-2011, 07:36 AM   #45
1991 33' Land Yacht
Warren , Ohio
Me too
I also have a ceiling that is beginning to sag. I have been to two local auto upholsters and their message is the same as I have been reading. You got to tear it out and redo it. The 1991 Land Yacht 33 Motor home has a fiber board ceiling, that the foam vinyl is attached to. Has anyone dealt with this type of backing? Can I use the brake cleaner on this? Can I buy the same foam backed vinyl from the Airstream factory?
Thanks in advance
johndes is offline   Reply With Quote
Old 09-08-2011, 12:09 PM   #46
richinny's Avatar
2011 34' Classic
there are lots of posts about this. pick one or a few from this list:
Google Custom Search
Ricky
Old 12-10-2012, 06:47 PM   #47
2002 27' Safari
Churchville , Maryland
Fasteners
Originally Posted by Inland RV Center, In View Post
It doesn't matter what adhesive you may want to use, it will not work until you completely remove the old adhesive.
The old adhesive is the problem. Adding more adhesive to a bad adhesive, is a waste of time and money.
Two things you can do.
Install screws, or remove the foam backed vinyl, clean off "ALL" the old adhesive, and then install new foam baked vinyl.
Again, the old, "BAD" adhesive is on the foam as well. You will have trouble trying to get it off the foam, without destroying the foam.
Not what you want to hear, but you will waste your time and money, if you try any salvage routine, other than the screws.
The Airstream factory, also says, it can't be done.
Jackson Center quoted me $7,700.00 and seven days in the shop to replace the headliner in my 27 foot 2002 Safari. I am not sure that is a good investment.
What length of screw is recommended? Are there decorative washers to use with screws?
Cable is offline   Reply With Quote
Old 12-10-2012, 07:16 PM   #48
OUCH!!!!!
I did not know they had "gold plated" headliner material.
There are all kids of decorative washers available.
The most common is chrome plated.
3/8 to 1/2 inch long screws are more than long enough.
Old 12-11-2012, 07:08 AM   #49
1991 33' Land Yacht
Warren , Ohio
Sagging Celing
What we did. Removing the old adhesive is the real problem, almost impossible. The first section came down and we removed the old adhesive by scraping with a razor blade. Took forever. Then glued a hard board ceiling panel, purchased from an RV supply store (Sands RV Madison, OH) to the wood ceiling. It looked so good we took the next section down and did the same thing, except we DID NOT remove the old adhesive. Using construction adhesive (Home Depot) we glued right over the old stuff, looks great and is very permanent. We have a 1991 Airstream Land Yacht these panels were installed in the bedroom.
Old 12-11-2012, 07:48 AM   #50
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
When we do one instead trying to get all the old glue off. We recover the ceiling in underbelly aluminum which is thin cheap and light and then glue the new vinyl to it.
It definitely must be heat related as we see very little of the problem on Canadian units.
I would guess most of it is caused when the unit is closed up tight in storage and the internal temps go very high. A solar panel and a fantastic fan set to come on when the temperature goes over 90 might be a good investment.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 12-11-2012, 08:12 AM   #51
dznf0g's Avatar
Oswego , Illinois
To Andrew's point. That is the main reason I use MaxxAir vent covers. I leave my FF lids open 24/7/365 to allow ventilation while in storage. Keeps temps under control and doesn't allow mold and mildew to get a start.
-Rich-
Old 12-12-2012, 06:58 AM   #52
Joliet , SW of Chicago
Images: 33
Saggy ceiling liner
Our first AS, a 1994 Excella front kitchen, bedroom ceiling began delaminating about six months into owning her. We debated. We read. We prayed it would only be the bedroom ceiling!!
Then, my husband, armed with eye protection, breathing apparatus because of the fine particulate crumble the yellow foam backing had become, and painter's blade slowly began the week long joy of scraping, vacuuming, and removing the headliner. Secondly, he used an aerosol paint stripper and plastic paint spatulas to remove the goop, and finally acetone to remove the last layer of debris. Ultimately, my husband was exhausted, but the headliner never looked so good!!
Best of luck with whichever method you choose.
Lucy749
Lucy749
Lucy749 is offline   Reply With Quote
Old 12-12-2012, 08:02 AM   #53
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Tell me how the stripper and plastic scrapper worked out.
Old 12-12-2012, 01:17 PM   #54
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
You don't have to use chrome plated washers or screws. Stainless steel is readily available and probably cheaper.
Gene
Old 12-12-2012, 01:21 PM   #55
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Another member sent me a PM and said he used Goo Gone to get rid of the glue, with good results. We plan to try it on one of our panels this winter. I can rub the residue off pretty easily so I think it'll work...
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 12-12-2012, 02:27 PM   #56
1965 22' Safari
Send a message via Skype™ to chromis
Isn't Stainless + Aluminium + Moisture bad ?
chromis is offline   Reply With Quote
Sagging shower head K E Stabler Sinks, Showers & Toilets 15 03-31-2008 01:18 PM
sagging kitchen counter tandemfish General Motorhome Topics 6 10-17-2006 07:39 PM
Sagging rear bumper igenerally Bumpers & Bumper Storage 1 05-08-2005 07:42 PM
Sagging Door in '92 300LE fangthorpe Airstream Motorhome Forums 3 12-30-2003 02:02 PM
Sagging Shower w9det 2001 Safari 1 09-12-2003 01:28 PM
