Old 07-31-2003, 11:17 AM   #1
ronnie_g's Avatar
1995 34' Excella
Pembroke Pines , Florida
Headliner falling off, looking for a fix
I have a 1995 Excella, have noticed the headliner was loose in spots. Then this past Tuesday 1/3 of it fell down in the bedroom.
It appears that the foam has rotted and it is no longer able to hold the vinyl to the skin.
Is their a 'quick & easy' fix for this, or is it time to take it down to the base metal and start over?
So far the tech support from Aistream has suggested spray adhesive. I tried that on a old car years ago, the foam just pulls apart at another layer and you spray again and again....
Thanks for any suggestions?
Maybe a thin carpet? How should I attach it?
ronnie_g is offline   Reply With Quote
Old 07-31-2003, 11:34 AM   #2
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Possibly
The current International AS and the Safaris use a fuzzy, fabric headliner. This is in the parts catalog and should be available from Airstream by the yard. The fabric is lightweight and a single layer that should not separate like the foam.
Mine drooped in one place and I pulled off the trim strip and used 3M spray adhesive to reseat it. It has held well for a year now.
John W. Irwin
WBCCI #9632
Old 07-31-2003, 12:36 PM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I had one spot and what I did was take a suringe with some plain elmer's glue and very carefully injected some behind the fabric. Held it in place for about 5 minutes and it seems to have held. You wouldn't be able to tell the difference between factory and non-factory!
wheel trim fix? cherring On The Road... 10 09-24-2003 01:47 PM
Wallpaper falling off overlander76 Upholstery, Blinds, Walls & Interior Finishes 3 07-04-2003 07:55 AM
vintage windows falling out--why? BevnCraig Windows & Screens 13 04-16-2003 06:23 AM
How do you repair cracks in the headliner of a 1985 325 Motorhome rdm General Interior Topics 3 08-03-2002 08:19 AM
wiring fix? ALANSD Airstream Motorhome Forums 9 06-20-2002 07:40 AM
