05-22-2018, 11:58 PM
1990 29' Excella
baltimore
, Maryland
Has anyone tried dying their curtains?
Hi,
I was thinking that dying the curtains might spruce them up?
gh
05-23-2018, 08:07 AM
1974 27' Overlander
Baltimore
, Maryland
Not in the Airstream, but I did in my house. The curtains we're pink when I bought it. Bleached them and dyed them lime green. Came out really nice. The folks I sold the house to three years ago just put the house on the market, and those curtains are still there.
05-23-2018, 09:14 AM
1969 18' Caravel
Greenville
, whereEverIroam
Groovy!
For some reason, an image like this popped into my head
Not sure if you want this much fun in your Airstream, but it would be quite the trip!
05-23-2018, 10:10 AM
2007 22' International CCD
Corona
Definitely "trippy"...
05-23-2018, 07:24 PM
1990 29' Excella
baltimore
, Maryland
Yes, I like fun.
Im not sure Im fast enough to catch it anymore.
But I continue trying.
Sort of fun is good too. Its slower.
05-23-2018, 07:31 PM
1990 29' Excella
baltimore
, Maryland
Greatleys... gurgle on the wood stove.
I have thought of this, but what of the tanks below?
what if you get the minus 10 degree night, and the wood stove is on, and the furnace is not heating the fresh/black/grey tanks?
05-23-2018, 07:33 PM
1990 29' Excella
baltimore
, Maryland
When you dye cloth, does the chosen dye or procedure depend on the type of cloth?
ie. polyester vs cotton
05-23-2018, 07:44 PM
1974 27' Overlander
Baltimore
, Maryland
I have electric heaters on my fresh and primary gray tank. I also have a return line from the water heater to the fresh tank, so I can recirculate heated water into the fresh tank off-grid, controlled by a thermostat and a solenoid valve.
05-23-2018, 07:51 PM
1990 29' Excella
baltimore
, Maryland
LOL. yes of course... why didnt i think of that.
Wait.. electric. So what if you are out in the woods and have no electric hook up?
05-23-2018, 07:54 PM
1974 27' Overlander
Baltimore
, Maryland
05-23-2018, 08:00 PM
1990 29' Excella
baltimore
, Maryland
dont you need a pump? to push the hot water to the fresh tank and back to the hot water heater?
What about the grey and black?
05-23-2018, 08:41 PM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
My guess....when the solenoid opens its just like opening any faucet but its piped back into the tank instead of running down the drain. Not sure the pump would be very plesant to listen to running that much.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
05-23-2018, 08:43 PM
1974 27' Overlander
Baltimore
, Maryland
Yes. The water pump does that. Same one that pulls water out of the tank and pushes it to the faucets. Dump water back in the tank from the water heater and it'll just pump it in a circle until the tank reaches the set temperature and the thermostat closes the valve.
I have a composting toilet, so no black tank to worry about. The gray tank will freeze if I don't have hookups or enough solar to run the heater. I can either empty it as I use it, or let it freeze and thaw it out when I have electric. Or put dish bins in the sinks and not let the water go into the gray tank in the first place. Hasn't really been a problem.
05-23-2018, 08:54 PM
1974 27' Overlander
Baltimore
, Maryland
With a silencing kit and an expansion tank, it's pretty quiet. And it doesn't take long to raise the tank temp a few degrees to hit the setpoint. 45 gallons or less, 5 GPM, 140 degree water.
Not saying everybody should go tear out their furnace tomorrow, but mine was shot anyway, and I needed space for the dishwasher. This setup works well for me. It also allows me to prime the hot water lines without wasting any water.
This curtain discussion has certainly gone off the rails. When I dyed my curtains, the cotton fabric took the dye differently than the synthetic thread, so they ended up slightly different colors. The thread turned out yellow while the curtains we're lime green. It was a nice effect on mine, but of you were looking for uniform color, you may end up surprised at what you get.
