02-26-2017, 06:48 PM
1967 26' Overlander
Eugene
, Oregon
Good Products to Clean Vinyl Walls, Ceiling? We're Restoring Our 67 Overlander
Anyone found a good cleaner that's not abrasive but will really clean the vinyl to its original white? I was thinking just good ol bleach n warm water, but I don't want to do any damage. It's in great shape for a 67'
Thanks in advance!!
Warm Regards from the "Granny Jo"
Stephie Jo
02-26-2017, 07:13 PM
Dazed and Confused
Hillsburgh
, Ontario
I wouldn't use bleach! We used a product called Spray-Nine; it is not only a marvelous cleaner but an effective antivirus, antibacterial agent as well, that is safe to use and smells pretty good to boot. We must have used 3 gallons on our 310 before it was all spic and span.
http://www.spraynine.ca/product/spra...duty-cleaner-7
Cheers
Tony
02-26-2017, 09:29 PM
2023 25' Flying Cloud
Richmond
, Virginia
Thanks in advance!!
I used Greased Lightning on my '67 and the walls cleaned up really well. Available at the big home improvement stores.
02-27-2017, 03:31 PM
1967 17' Caravel
Oak Creek
I used Marine Clean diluted 2:1. My Caravel walls were filthy & now look new. The sticky has not come back.
02-27-2017, 07:15 PM
1966 24' Tradewind
Kansas City
, Missouri
I used Comet cleanser and a power washer.
02-28-2017, 10:26 AM
1967 26' Overlander
Eugene
, Oregon
Thanks guys! No bleach
Stephie Jo
02-28-2017, 11:33 AM
NO HUMBLE OPINION
1968 20' Globetrotter
ANN ARBOR
, THE GREAT LAKES
"really clean the vinyl to its original white?"
Hi There,
I don't think that it was ever "white". After days of cleaning with everything imaginable, TSP, magic erasers, bottles of purple stuff, green stuff, yellow... with clear water rinses in-between, my '68 walls were indeed very clean, free of marks and stains. The color is a creamy, light beige with a tan colored embossed weave. It of course varies with the amount of sunlight, but definitely not white.
I could be mistaken, but I think my walls look like new.
The wall texture photos are taken with flash, and without, on a Michigan grey sky day. In direct sunlight, they're brightly reflective, then take on a warmth in the evening light, that compliments the woodwork comfortably. The pictures are not "before and after" cleaning, they're all "after" cleaning in different light.
Like Ms Dingo, in five years since cleaning, my walls have never been "sticky" as some are troubled by. There is a particular clear liquid floor wax that some apply to their clean vinyl walls, but I have not. I would think that clean original walls would be of greater value than painted-over vinyl.
It'll probably take a few cleanings. That original vinyl is factory (Kaiser or ALCOA??) bonded to the aluminum, and really high quality tough stuff, way better than paint.
Best luck
02-28-2017, 11:35 AM
2019 26' Flying Cloud
Colorado Springs
, CO
Krud Kutter worked great in getting years of gunk off of the walls of a '74 Tradewind.
02-28-2017, 11:41 AM
1973 Argosy 24
hartselle
, Alabama
I used 409 on the green scrubber side of a kitchen sponge for the first pass. Squirted 409 back on everything and wiped with paper towelss. Left mine looking like it was 1973 again.
02-28-2017, 02:25 PM
1968 22' Safari
Shillington
, Pennsylvania
Vintage vinyl wall cleaner
We have used a product called "spray nine" for 25 years on the walls of our 1968 Safarii. First found it at a paint store where it was recommended because it did not leave any residue. It cleans very well but keep windows open for fresh air while working.
02-28-2017, 03:30 PM
1971 31' Sovereign
Temple
We had excellent results with the extra strength Mr. Clean Magic Erasers.
02-28-2017, 10:30 PM
1974 Argosy 26
Morrill
, Nebraska
Full strength Simple Green. Rinse with plain water.
03-01-2017, 06:29 PM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
Skaterio suggest this to me and it worked great on a crusty, sticky 1970.
Water, Ammonia, Dawn dish detergent, and baking soda. Mix for a strong solution and ventilate well when using. Rinse with water. It only took one pass on most of the interior.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
03-03-2017, 08:58 PM
1967 26' Overlander
Eugene
, Oregon
Hi There,
Best luck
Looks great! I know there is no such thing as white in an original 67, lol.. but I think you know what I was going for. I'll show some before and after pictures tomorrow! It's going to be done w help from 2 very non excited, but they're going to get excited teenage girls!
We're going to go with marine clean and see if IRS as good as it sounds!
Thanks for input, so appreciated!
Stephie Jo
03-03-2017, 09:11 PM
1967 26' Overlander
Eugene
, Oregon
Next question: pics below tub has a few small cracks and needs repair in that one corner.
Fiberglass repair kit for corner and cracks?
Followed by Whitecote POR-15
For gel coat? I heard this Whitecote needs no sanding etc ( just good cleaning) but just brush or spray and you have sturdy, hard, weatherized tub n sink?
We are not removing and dismantling everything.
Just want to get a good clean looking tub.
I wanted to keep original puke 60's yellow, but it needs repair so I guess we'll just have a clean resurfaced white tub.
Anyone work w something better than Whitecote?
Once this is done
Plumbing electrical check
Then countertop (Corian) bamboo floors
And reassemble front gaucho ( new foam)
And twin bed assembly, I'm hoping we're well on our way!!
Decided to keep original lighting just add LED lights
But wow, we've never owned a trailer
Just figuring out how the battery system works and the plumbing and the tubes and the more weird boxes and cords, and stuff and more stuff
It's a little crazy!
Stephie Jo
03-03-2017, 09:18 PM
1967 26' Overlander
Eugene
, Oregon
Hi There,
Best luck
Look Great! That's where we want to be
Stephie Jo
03-03-2017, 09:19 PM
1967 26' Overlander
Eugene
, Oregon
Did one product work better than another?
Stephie Jo
03-04-2017, 03:53 AM
1967 17' Caravel
Oak Creek
I did not use the Future floor wax on my vinyl clad walls either. So far so good.
03-04-2017, 04:01 AM
1967 17' Caravel
Oak Creek
Here is a before & after. The before is covered in mouse pee & 45+ years of pure filth.
I'm so happy I rescued this trailer. :-)
03-05-2017, 03:11 PM
1967 26' Overlander
Eugene
, Oregon
Wow, looks new! So you used a floor wax? So far weve
Stephie Jo
