Old 07-25-2007, 03:49 PM   #1
dudebb's Avatar
1962 16' Bambi
Newtown Square , Pennsylvania
Gaucho Puzzle - How many cushions??
We are going tomorrow to get new foam for the gauchos for our 62 Bambi as a part of the rehab and reupholstery. The 72' long straight gaucho along the side wall currently has 3 cushions which include the back bolster that is also used as a section of the bed mattress when the bed is pulled out. I'm trying to figure out why there are 3 cushions. I would think that the seat should be just 1 cushion 32" wide (it is now 2 cushions 22" and 10") and that the back bolster 15" would be used to fill in the "pulled out" space when you want to make it a bed. Does anyone else have 3 cushions and do you know any particular reason there are 3 instead of 2 ?? Any thoughts would be apprciated.
George
1962 16' Bambi (sold )
1996 Buick Roadmaster Estate Wagon
Airforums# 7906, WBCCI #4248, WDCU
dudebb is offline   Reply With Quote
Old 07-25-2007, 04:08 PM   #2
aluminauti
whitelight's Avatar
Where we , Park it!
George - do you have a picture to post of the old cushions?
I don't have a photo handy - we redid our cushions by paring down from 3 to two pieces of foam - the "base", or seat, as you suggest, would be one cushion of 32" deep. The bolster would then be the bed fill piece.
The older style cushions were designed as 3 pieces with the "back" foam piece hinged to the seat. The theory in this design was to keep the back off the wall/resting against a support as well as define the seat depth - problem is, as the foam shrank over the years, the "back" usually would not lean against the back support & tend to collapse.
If you go the route that you are suggesting, I'd figure out a way (velcro, snaps, etc.) to keep the back in place when being used as a settee.
whitelight is offline   Reply With Quote
Old 07-25-2007, 04:13 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Do these pictures from Vintage Airstream help you any....
Vintage Airstream - '62 Bambi
Old 07-25-2007, 05:07 PM   #4
dudebb's Avatar
1962 16' Bambi
Hi Whitelight and Ganglin,
Thanks for responding. Yes, the back cushion currently has the two metal loops attached to attach it to the piece of wood that runs on the wall behind the seat. I plan on re-using these (and hoping to find the other pieces that attach to the piece of wood). My current back cushion also has a piece of plywood in the back for support behind the foam which should support it and prevent the foam from collapsing. The Vintage Airstream photos are helpful, thanks for sending them.
I just can't see a good reason to have originally made this a 3 cushion seat / bed.
Thanks again!
George
Old 07-25-2007, 08:34 PM   #5
aluminauti
whitelight's Avatar
Where we , Park it!
Here's an "after" picture of cushions I did on the 74 31'. The side gaucho seat is one piece of foam. I did leave the thin plywood in the seat back. The aluminum curtain track supports the back. This aluminum track had a 1" vertical insert; I put velcro here & then sewed velcro in the back of the cushion - this really keeps the back in place!
The "original" three piece with the hinged back was supposed to be "easy" to pull down the gaucho to make the bed . . .
good luck with the project George - and go for the two piece look!
Name:	1new interior forward dinette with fold down table.JPG
Old 07-26-2007, 12:05 AM   #6
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
My '72 also has the three piece. The bottom two have wood supports to span the metal slides. I see no reason why you couldn't modify it to a 2 piece cushion. It would be much more comfortable without the crack under your back.
I could send photos tomorrow if it would help. If so, PM me.
Dave
Fyrzowt is offline   Reply With Quote
Old 07-29-2007, 09:57 AM   #7
Silver Threads's Avatar
2000 25' Excella
Kingston , Tennessee
3 vs 2 Cushions
In our 72, When I first tried to figure out how to make a gaucho cover and coudn't, I simply did what you are talking about and just made simple zipper cover for them. The problem came when we tried to sleep on them. My husband kept falling in the cracks. I tried using bungee cords and eveyrhing I could to hold them together but with no avail. I finally ended up figuring the cover out and put them back the way they were meant to be and havent had any more problems. Im not saying you will have this problem, but I would try it out first. The back " banana shaped" cushion on ours is there for the back seat cushion to rest upon when it is couch form, and fills in the back when it is a bed.
ID:	42118   Click image for larger version
John & Tammy Adams
Silver Threads Custom RV Curtains
2000 Airstream Excella | AIR 15902
https://www.etsy.com/your/listings
Silver Threads is offline   Reply With Quote
Old 07-29-2007, 07:42 PM   #8
Fyrzowt's Avatar
Images: 8
You can't get around having the crack in the middle and falling in as long as the bottom cushion is split. You can make the bottom cushion one piece, or do something similar to me. I put memory foam on top which spans the crack and feels like our Tempurepedic at home. Good luck with it.
Dave
2003 International AS Pahaska 2002 - 2005 International 149 10-01-2017 07:38 PM
size of cushions on side gaucho Stan Z 1956 - 1965 Caravel 6 05-25-2015 11:18 AM
WANTED: Front Dinette Photos InsideOut General Interior Topics 21 01-12-2007 04:09 PM
Cushion Dimensions, Front Sofa Alan and Julie General Interior Topics 2 08-05-2002 03:14 PM
Where to get new cushions made? Andy R Upholstery, Blinds, Walls & Interior Finishes 8 04-16-2002 02:32 PM
