Old 08-19-2015, 09:04 AM   #1
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Gaucho Extension! Flip down legs
I wanted more space out of the bed up front with my Gaucho. I removed the stop blocks inside, and sure enough, got another 8 inches, but the cantilever was too much. So, I made flip down support legs.
They swing down on nylon washers, and have a block that stops them when they are vertical. Then, when you are ready to put the bed away, you flip them up, and a super magnet grabs the L shaped piece of metal and holds them up out of the way while you push the bed back in place. It works great, and when you sit on the edge of the bed, there's no flex to the support arms as the weight is carried by the new legs.
ID:	245847   Click image for larger version
robwok is offline   Reply With Quote
Old 08-19-2015, 05:02 PM   #2
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
Your pic did not show up but it sounds like what I did on our trailer makes a real solid bed.
thehandyman is offline   Reply With Quote
Old 08-19-2015, 05:41 PM   #3
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Try posting pics again please.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 08-20-2015, 07:01 AM   #4
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Pics
Okay, I tried again. It just keeps saying it failed. Not sure what the issue is.
Sorry.
Old 08-20-2015, 10:14 AM   #5
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
okay
Looks like it worked
ID:	245868   Click image for larger version
Old 08-20-2015, 10:45 AM   #6
mandolindave's Avatar
Great idea…looks like great design.
Don't know if it would work on mine, but sure would like to see a close up from the other side.
mandolindave is offline   Reply With Quote
Old 08-20-2015, 11:05 AM   #7
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Which side do you mean? There are actually 3 legs spaced across each of the 3 supports. There are some things you have to be careful of. you need to clear the top of the front, when you put in the blocks where the legs drop down and stop, those need to allow you to close the front. I had to use T nuts in the front since that's upholstered. I'm going to use thread lock in those. You also want to space the legs out a little from the back so it can still drop if you upholster the front.
Old 08-22-2015, 09:41 AM   #8
1968 30' Sovereign
New Richmond , Wisconsin
We're in the exact same situation - trying to figure a way to make the front gaucho extend more. This seems like it may be an answer. I also would love to see some closeup pics of the other side - ie - the side that would show where and how you attached those legs. Also - in your first post you mention using super magnets to grab on to the L-shaped piece of metal. Can you please clarify what L-shaped piece of metal you are talking about! Thanks for the great idea!
cheetah1 is offline   Reply With Quote
Old 08-22-2015, 09:40 PM   #9
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
Hey Rob,
I sawed off two folding table supports from V T S and mounted them on each corner. They just snap up then slide in.
Tim
Beaker63 is offline   Reply With Quote
Old 08-25-2015, 09:01 AM   #10
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Cheetah1: In the pic, you see that little circle in the leg? then near the end of the leg you can see a shiny square. What I did was use a super magnet that was designed for screwing on. It has a hole, and a recessed area for a countersunk screw. You drill the hole with a forstner bit, then screw in the magnet so it's flush. then, you use 1" "L" brackets. These are usually used for small shelves or to repair a corner in something. I believe these are 1/2" on each leg and each leg has a screw hole. So, when the leg swings up, the magnet grabs the top of the L shape that is sticking out.
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Gaucho - New Frame / Extension Whizzo Cabinets, Counter Tops & Furnishings 0 01-24-2010 02:30 PM
Skinny Legs and All funkill Off Topic Forum 3 10-06-2008 01:31 PM
What do the Gaucho Legs look like? hellokitty General Interior Topics 13 03-17-2008 01:28 PM
Gaucho extension-any success stories?? Creampuff Cabinets, Counter Tops & Furnishings 29 10-14-2004 02:16 PM
