Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 04-23-2008, 11:38 AM   #1
Profile:
1964 Safari curtain pattern & measurements
Hi folks,
Does anyone have original drapes /curtains from a 1964 Airstream Safari they would be willing to loan, sell or share photos of?
Needed as sample / pattern / measurements.
Tammy is going to make up my new curtains. I don’t have any of the originals.
The original top rail and hanger slides are in place. Apparently there was no bottom rail and pleats at top only.
We need to know details of the “snugger cord pocket” on the lining side to keep curtain pulled against wall, total length top to bottom, side to side etc.
My Safari has front dinette with jalousie windows both sides and street side gaucho windows.
Yes, I checked about purchasing drapes from J Ambruso, They tell me they no longer make drapes for ’68 or older Airstreams and do not have pattern / measurements available.
Thanks for the help,
Walter
walter1 is offline   Reply With Quote
Old 04-23-2008, 04:08 PM   #2
Foiled Again's Avatar
Profile:  2005 22' International CCD
Virginia Beach , Virginia
Basic Curtain Guidelines
I've known several commercial seamstresses, and it is possible to make curtains starting by making your own pattern. Your local sewing center may even have a few books. Of course the wrap around windows defy the old rectangular piece of fabric rule... so here goes.
If you want to do formal tucked drapes... talk yourself out of it, it's a pain in the ****, skip right down to the next section. So here's the PIA tucked method:
Basic rule to buy fabric for tucked drapes. To make a finished panel 30 inches wide, you'll need to start with fabric that is 90 to 120 inches wide - which means seaming the fabric pieces together.
To make your pattern, get some heavy and wide butcher paper or brown wrapping paper and tape it over the windows leaving whatever margin you think correct to fit over the top (and if you have them bottom rails). Allow some overlap on each side too. I use masking tape because it leaves no residue if you remove it promptly. The pieces that go over the sied wrap arounds will actually have a shape vaguely like a slice of angel food cake - wider at the bottom, with a slight inward curve on the top and a slight outward curve on the bottom. Make your marks with a pencil, then cut out - and you'll have the size and shape of the finished panel. Add 1.5 inches to each side to fold over, finish and attach through the lining onto the curtain. on the curved pie shape, it's difficult to do a fold over, so I add a 5/8 inch seam allowance and cut a strip 4 5/8 inch wide for the top foldover, then sew it on. Decide how wide you want your tucks to be and how deep (use the top allowance - it needs to come out evenly so if the finished length will be 30 inches, you'll want a number of tucks that divides evenly into that - at 3 inches can have 8 tucks and leave three inches plain on each end. Figure your fabric used for each tuck - if I choose a three fold tuck that's 5/8" deep it will take 5/8" it will take a pinch over 3 1/2 inches of fabric per tuck. Add that to the width of each panel for each tuck. The bottom edge of the wrap around panel will be about 8 inches longer than the top. To put in the tucks you'll have to space them further apart but keep the tucks the same depth. (I did my first one on a cheap old sheet as a test.).....
NOW SOBER UP AND TRY something easier. IGNORE the fact that the side windows are trapezoidal - make a rectangular curtain based on the bottom measurement and once on the curtain carriers let the top be a little more gathered than the bottom. If you're using a plaid fabric it will actually look better if you just make the panel rectangular.
ALTERNATIVE #3 - even easier and with the right fabric choice very attractive - Gathered drapes. Not suitable for heavy fabrics like velvet, but works fine for lighter weight fabrics even with a lining. You'll possibly have to look in K-mart for cheap spring rods. You may have noticed that sheer curtains placed over doors with windows or sidelights to those doors are often secured top and bottom with a spring instead of a rod. The flexible spring hooks over two small flat hooks at each edge.
Make rectangular curtains 3 to 4 times wider than the window you want to cover and leave a pocket to gather them up (threading the spring through the pocket). Most people leave a 1 to 2 inch ruffle above the pocket - attractive and prevents the edges of the curtain from fraying due to stress from the rod. Works great on a flat window. On the curved wrap around windows, you COULD use this same idea if you have top and bottom curtain carriers. Just hand sew the little plastic curtain carriers to the back of the pocket about every 4 inches. Slide the plastic pieces into the slots, then stretch the spring and fasten to screws at each end of the window.
There is another way to make gathered drapes - permanently on a flat backing piece - but the previous way lets the gathers come out when you want to launder and iron them.
Hope that helps.
Today is a gift. That's why they call it "the present"
Old 04-23-2008, 06:26 PM   #3
Commercial Vendor
Silver Threads's Avatar
Profile:  1966 24' Tradewind
Kingston , Tennessee
Thanks for the info. I have figured it out but for some reason he isnt getting my emails.
John and Tammy Adams
AIR # 15902
Visit our websites, http://www.freewebs.com/silver-threads/
http://restoringour66tradewind.blogspot.com/
Silver Threads is offline   Reply With Quote
Old 04-23-2008, 07:25 PM   #4
Profile:
Thanks a lot. Whew!, now I'm scared. Tammy to the rescue. I'm in nowhere land (Canada) with email flaky. Forum PM seems to work.
Thanks, both of you.
Old 04-24-2008, 06:57 AM   #5
starflyte1's Avatar
Profile:  2007 25' Safari FB SE
Bonita Springs , Florida
I called Colaw Salvage in Carthage, Mo. They are sending me one panel from a Classic. I'm only paying postage because they said it is not a pretty piece, but that's ok with me.
Pat
AIR# 16756
WBCCI# 6167
starflyte1 is offline   Reply With Quote
Old 04-24-2008, 07:19 PM   #6
Commercial Vendor
Thanks Pat, I will give them a call and see if they have one.
AIR # 15902
Old 04-28-2008, 05:12 PM   #7
Profile:  1962 22' Safari
westminster , Colorado
1962 Safari curtain issues
Have been a long time lurker on this site and now it is time for me to ask a question. I am a seamstress but I make clothes not Airstream drapery so I'm having a problem with the type of curtain hardware that goes with our Airstream. It is the Tab type, not the kind with the elastic. There is just this piece of square plastic and I really don't think I sew that to the fabric do I? I'm thinking my old Singer won't even sew through plastic. We tried the slider kind and the top part would not go through the existing curtain holder. I have searched the web trying to find a good picture of a Safari and drapes to give me a clue but I can't find a photo anywhere. Photos would be awesome if anyone has them. If you need a photo of the type of tabs that I have let me know. And I appreciate any information you can give me.
Jilli
jilli is offline   Reply With Quote
Old 04-30-2008, 04:52 PM   #8
toddster's Avatar
Profile:  1964 22' Safari
Campbell , California
I have a '64 Safari (double model) with original curtains (I think). Problem is that when I purchased the trailer, all of them were thrown in the shower. I do not know what goes where. PM me and maybe I can offer some assistance.
toddster is offline   Reply With Quote
Old 05-05-2008, 11:06 PM   #9
Profile:
Hi Toddster. I sent PM. Thanks for the offer to help
Old 05-06-2008, 08:20 PM   #10
Commercial Vendor
Hi Jilli, it sounds like you have the same kind that I have in my tradewind. It just uses regular curtain hooks like these. I just put one in every pleat.
AIR # 15902
Pingbacks are On
shower curtain pattern Lana 1966 - 1968 Safari 30 05-26-2007 03:50 PM
measurements safari 1994 Holland The Vendor's Forum 3 12-15-2006 05:23 AM
Lug Pattern for 99 Safari Share All Wheels 3 07-05-2006 07:43 PM
curtain measurements angie@smartw Upholstery, Blinds, Walls & Interior Finishes 6 01-14-2006 05:31 AM
Curtain Pattern for '62 Bambi Marshall44 Upholstery, Blinds, Walls & Interior Finishes 15 03-17-2003 07:03 PM
SEO by vBSEO 3.1.0
