Old 03-23-2010, 03:59 AM   #1
Yomster's Avatar
1968 26' Overlander
London (UK) / San Francisco , London / California
Images: 13
Front Gaucho Pattern Needed for '68 Overlander
I'm planning to recover the gaucho in our '68 Overlander.
Has anyone got a pattern or dimensions I can use as a template for the project?
The trailer is quite far away from where I am currently located, measuring it wont happen for a month or so. I'd like to get cracking on with a newly acquired sewing machine.
Thank you
Yomster
Yomster is offline   Reply With Quote
Old 03-23-2010, 04:49 AM   #2
kokopat's Avatar
Hendersonville, NC , North Carolina
Front Couch
My niece has mine right now - 5 hours away in NC. I'll ask her to give me some numbers for you.
Pat
kokopat is offline   Reply With Quote
Old 03-23-2010, 05:23 PM   #3
kokopat's Avatar
Here's your numbers for the couch
Couch Bottom
6" Thick
73" Length
21 1/2" Width
*overall shape is a rectangle
Couch Back
6" Thick
73" Length
15" Wide
*front facing fabric is 15" and has a tapper down to 12" in the back. The top edge appears to have the tapered edge, not the bottom
*The Couch Back and Couch Bottom are attached to allow for the unit to lay flat for a bed.
"Hidden" Insert
6" Thick
73" Length
13" Width at the mid-point of the cushion
*This piece has a curved edge that needs to be matched to the contour of your trailer.
Also the original pieces had plywood in them. We are opting not to reinstall the plywood.
Hope this helps... Pat
Old 03-23-2010, 06:36 PM   #4
Yomster's Avatar
1968 26' Overlander
Images: 13
Thank you!!!!! This is awesome, and very much appreciated,
All best wishes
Yomster
Old 06-14-2013, 11:39 AM   #5
1964 26' Overlander
Toronto , Ontario
Boy! This really helped me, too! Thanks loads. How is your gaucho without the plywood? I'm thinking of the same thing...
wigwag is offline   Reply With Quote
Old 06-14-2013, 06:57 PM   #6
kokopat's Avatar
Sorry, we went back and added the plywood to the upright back and the short piece used when made into a bed. After remaking the gaucho, it is still not worth sitting on for a long time...
Glad the measurements helped.
Pat
Old 06-15-2013, 06:56 AM   #7
1964 26' Overlander
Toronto , Ontario
Oh. That's too bad. Even with the 6" foam. Hmm. Thanks, Pat.
Old 06-15-2013, 07:53 AM   #8
1973 25' Tradewind
Beautiful , Oregon
Anyone with a solution that works and they are happy with. Pictures of the finished product great or better yet the construction. I am sure a lot of people would benefit.
Thanks Tony
Tony S is offline   Reply With Quote
1968, gaucho, overlander, recover
Looking for front gaucho plans Walker's Wanderer General Interior Topics 10 11-11-2009 11:05 AM
Need front gaucho '73 MAVERICK All Argosy Trailers 0 07-19-2009 08:40 PM
? about the floor under the front gaucho drowe42 Repairing/Replacing Floor &/or Frame 5 03-07-2009 07:29 PM
Front gaucho or dinette? bobfowler All Argosy Trailers 27 01-03-2009 06:42 AM
Small Shelf behind front Gaucho Silver Threads Cabinets, Counter Tops & Furnishings 22 06-06-2007 04:22 PM
