Old 02-22-2013, 09:01 AM   #1
1964 24' Tradewind
Lawrence , Kansas
Finshing Cabinet on the '64 Tradewind
So I am about to refinish the oak woodwork in the 64. I have reworked the veneer where it was bad. Constructed 5 new doors with 3/8 plywood with red oak veneer applied. And here is what I am thinking.
I have had a stain mixed to match the existing "aged finish" to stain the new veneered doors and I am thinking of applying one coat of orange shellac to help give the new doors an aged look. I am hoping this will bring the new doors to a look very close to the old finished woodwork. The next step of varnishing all of the woodwork is where I pause in my thinking. Normally I like using a brushing lacquer and hand rubbing it to give a nice soft luster but I am a little afraid of this approach for several reason: One the original lacquer most likely has had varnish put over it at some time and lacquer sometimes wrinkles oil based varnishes. Two, the old wood is really dry. This has got me thinking that tung oil might be a good idea for the finish coat because it might help address the dry wood issue. I know you all have lots of experience out there. Any suggestions?
ttbikes is offline   Reply With Quote
Old 02-22-2013, 09:04 AM   #2
There are professionals on this site who can probably provide more insight, but I like your tung oil idea for the reasons you listed.
Be sure to post some before and after pics, would love to see them.
Old 02-22-2013, 09:42 AM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
Test everything on samples and in concealed areas. Here, lacquer over varnish is usually considered a bad idea. Some refinishers mix BLO with poly and rub that out. If I was going over varnish, I'd probably just go over it with more varnish.
Old 02-22-2013, 09:45 AM   #4
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I used oil on my 66 cabinets looks very good. I will put orange oil on them every once in awhile to keep them from cracking.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 02-22-2013, 11:40 AM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Finshing Cabinet on the 64 Tradewind
Greetings ttbikes!
The quandry that you describe is familiar . . . when faced with similar questions about my '64 Overlander International, I was advised that WATCO oil finish was the product originally utilized on my Overlander. That is the product that was utilized to renew the finish on my coach's original cabinetry while the WATCO oil treatment was preceded by a coat of MinWax Golden Oak stain on the new veneers. It has been a decade since the process was completed and it is still almost impossible to determine where the new veneers were installed versus the "restored" originals.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
'73 Tradewind on the horizon pxlchk1 1970-79 Tradewind 7 02-05-2012 02:56 PM
HENSLEY CUB w/73 Tradewind my3sonsdad Hitches, Couplers & Balls 5 08-02-2011 07:31 PM
removing the heater and cabinet from a 70 Overlander rayandre Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-08-2011 08:17 PM
nt-22A cabinet tracker Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-13-2011 09:54 AM
1975 Tradewind project - questions! lots of them! keithmac 1970-79 Tradewind 4 03-05-2011 10:10 AM
