Old 05-05-2016, 12:52 PM   #1
mopariac's Avatar
1972 29' Ambassador
Weatherford , Texas
Final decision on window coverings
I have been going back and forth on whether to stick with curtains, install blinds or go with shades. A while back I attempted to install blinds between the window and the screen but found it to be harder to figure out than it was worth. I never did like our pleated curtains that came with our trailer so we decided to go with string-less shades from Home Depot. I have attached a few pictures to show my no-peeky design. We also pulled up our shag green carpet and put down some commercial-grade PVC flooring.
ID:	261972   Click image for larger version
ID:	261974   Click image for larger version
mopariac is offline   Reply With Quote
Old 05-05-2016, 12:59 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
The pleated shades look great and very up to date. That's very avant-garde for a 40+ year old Airstream.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 05-05-2016, 02:15 PM   #3
mopariac's Avatar
1972 29' Ambassador
Weatherford , Texas
Thanks Brian...thought I would share so others might see another option...Happy Streaming
Old 05-05-2016, 02:23 PM   #4
FCStreamer's Avatar
2014 30' Flying Cloud
These look very nice. I think I may go this route. Thanks!
I asked Colonial for a quote to put shades in the master of my 2014 FC 30. They said they could not do the back windows because it was "too big". For the other four windows, they quoted me $750 minus 10% discount.
I like this idea better. My hold up is drilling holes into the inside of my Airstream. I am not psychologically prepared to do that yet.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 05-05-2016, 04:22 PM   #5
mopariac's Avatar
1972 29' Ambassador
Weatherford , Texas
FCStreamer, Colonial said the rear window was too big? I have a single 72" wide shade covering the two side-by-side windows in the living room. And to let you know, the wood frame is attached mainly to the top and bottom with only 2 small rivet holes in the wall just under the top for a stabilizing bracket. If they ever got changed to something different, I could just fill the holes with rivets and only I would know they weren't doing anything but filling the hole.Good luck with whatever decision you go with!!
Old 05-05-2016, 04:28 PM   #6
FCStreamer's Avatar
Yes, I thought that was odd (the too big part). I'll have to measure but I am liking your solution a lot. I just have to learn how to make and cover holes in aluminum.
Old 05-05-2016, 05:14 PM   #7
moosetags's Avatar
I have been covering holes in the Airstream for years. My personal favorite is a stainless steel panhead screw. It just always looks like it belongs there. The next best would be an Olympic rivet. A standard pop rivet would be my last choice but would be fine also.
Brian
Old 05-05-2016, 05:29 PM   #8
FCStreamer's Avatar
I am complete noob when it comes to this. I'm thinking I will drill a hole straight through the trailer wall and into the outside.
So if these rivets are used inside
http://airstreamsupply.com/New-Rivet...-of-100-106285
Then it stands to reason the walls are at least that thick, otherwise the rivets would stick out the other side, correct?
And I am assuming you can put a rivet in a hole just to cover it up?
Old 05-05-2016, 09:30 PM   #9
moosetags's Avatar
No need to drill to the outside. Just fill the inside hole with a screw or rivet.
Brian
Old 05-05-2016, 10:28 PM   #10
Victoria , British Columbia
Looks very tidy, practical and freshwhat sized blinds did you get ? I don't like the pleated curtains .
Love the floor too. Very nicely done.
Katoline
katoline is offline   Reply With Quote
Old 05-06-2016, 05:50 AM   #11
1972 27' Overlander
Denver , North Carolina
Love em, mind if I borrow your ideas?
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 05-06-2016, 10:49 AM   #12
Airstream newcomer
1969 31' Sovereign
Spokane , Washington
Those are so elegant looking! Thank you very much for posting - I would definitely like to use your idea, if I may.
traileritus is offline   Reply With Quote
Old 05-06-2016, 11:12 AM   #13
DTR
Adventures with GypsyRose
DTR's Avatar
1988 32' Excella
Plano , Texas
That is a great idea! Thank you for sharing
DTR is offline   Reply With Quote
Old 05-07-2016, 10:13 PM   #14
mopariac's Avatar
1972 29' Ambassador
Weatherford , Texas
Yes, feel free to use any idea I have
If I can help in any way, just let me know...I will show all of the renovation as I complete each project, including bathroom, upholstery and hide-away tv stand next to the couch.
Old 05-08-2016, 07:38 AM   #15
1992 35' Airstream 350
Frisco, CO/Scottsdale, AZ , Denver, CO
We replaced the dated wooden blinds in our 1992 350 Classic Motorhome as soon as we bought it in 2004. We purchased made to measurements double cellular shades that could be lowered from the top or raised from the bottom. They look great and help control light, drafts, and temperature variations in the coach. I also made new pleated drapes for the front cab and curved back bedroom windows and lined them with sun resistant fabric like you would for windows in your home. I've never understood why Airstream put such cheap and flimsy curtains in their trailers and motorhomes.
Hal-Gin is offline   Reply With Quote
Old 09-18-2016, 04:07 PM   #16
Starstream's Avatar
Spring , Texas
Hi, mopariac. We originally considered doing something very similar with the windows which no longer had original curtains. Yours turned out very nice. Curtains aren't always my favorite thing, but it seemed like we were throwing out enough when we gutted the old interior. I just about killed myself to make the remaining curtains dark blue. They cover the front and back of the trailer. The remaining windows are covered with new blinds made from chenille and dark blue cotton duck. We got over our fear of screws a long time ago, so the new blinds are attached with screws over the windows. They're trimmed with matching cornices I made from a contrasting fabric and plastic baseboard trim made for linoleum floors.
The blinds are a flat piece of fabric with the side cut on a curve. The curves were folded back and edge-sewn to keep them to the sides. That was my no-peeky solution. I've made some very large Roman blinds for my house. Oi-vay! The cords! The AS blinds have simple ties at the top - two sets for each blind. Fabric to wall snaps hold them where we want them when closed.
Starstream is offline   Reply With Quote
Outside Window Coverings? happier Awnings 14 05-12-2009 03:23 PM
VCT tile question before final decision silverbeauty Floor Finishes 14 01-26-2009 09:30 PM
Discolored/oxidized exterior coverings jsprad Cleaning, Stripping & Polishing 0 10-02-2007 12:30 PM
Window Coverings Safari Tim Upholstery, Blinds, Walls & Interior Finishes 14 06-13-2005 06:32 PM
And one final - the coverings Bryanhu General Interior Topics 2 02-25-2004 05:49 AM
