Old 05-17-2016, 10:54 PM   #15
Cardinal283's Avatar
Dallas , Texas
Thanks guys. Those both look great. I have some new decisions to make now. Haha.
Cardinal283 is offline   Reply With Quote
Old 09-08-2016, 10:04 PM   #16
Stick on metal tile worked great for me. I have a bunch leftover if anyone is interrestedClick image for larger version
Name:	ImageUploadedByAirstream Forums1473393845.423542.jpg
HeikeET is offline   Reply With Quote
Old 09-08-2016, 10:19 PM   #17
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
The brushed aluminum look of the tiles adds a nice ambience.
Sirs Gawain & Galahad
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 08-19-2017, 07:42 AM   #18
Elgin , Illinois
I'm considering buying a 2007 19' bambi with a Midnight Sun with Tropical Oak wood finishes interior. The original brochure says the walls are fabric covered - they look off-white or white.
The pictures show strips that look like they may be holding the sections of the interior wall coverings together. Is the fabric glued into place?
Anyone have experience removing the covering to return to an aluminum interior?
Do you think this covering explains the really good price of this unit?
Thanks!
sdt2017 is offline   Reply With Quote
Old 08-19-2017, 12:25 PM   #19
Elgin , Illinois
Cloth wall covering in 2007 bambi
Forgot to add a picture....
Name:	Walls Covered.jpg
Old 08-19-2017, 10:49 PM   #20
I have a 2003 Bambi and took the carpet off it did not look like you could make the wall skin nice and shiny ... there is sprayed on glue and things on it. I put stick on tiles over it and am very happy with the results. See my post with pics on this forum. I actually have enough of the tile left and can sell it to you if you do decide to go this route ��
Old 08-20-2017, 07:04 AM   #21
Hometeam4
1997 25' Excella
Silver Spring , Maryland
Hi
I've taken the fabric or "mouse fur" off. It's really a nightmare. I had to first pull the fabric off exposing the yellow glue underneath. There are a couple links on this forum somewhere which I followed and altered. Look up "mouse fur". I basically used stripper and plastic razor blades, (literally 100s of these orange plastic razor blades), to get the glue off. What I had left was an interior aluminum that was not meant to be seen by the human eye. I'm not home to show you pictures but the quality of the interior wall was clearly done so poorly it was obvious that they knew the workmanship would be covered. Airstream confirmed this. Not only that but if you are going to attempt this I would advise you to take everything out, cabinets, fridge, stove, couch/bed, etc. I think this mouse fur was the first thing installed. I have a '97 Excella wide body. The walls are awful with this stained mouse fur. I redid the back bedroom and remade cabinets and the bed after stripping the walls. I bought marine vinyl to cover them and the "t" channels you were asking about from Airstream. I may not do that now. I've seen some excellent work done with rubberized paint but I'm not sure of the process. Good luck!
Hometeam4 is offline   Reply With Quote
fabric on the walls? okgypsy Interior Restoration Forum 3 07-16-2012 09:50 PM
removing dinette and putting fabric on walls Victorialhq Cabinets, Counter Tops & Furnishings 5 11-30-2009 10:41 PM
Painting fuzzy fabric walls dickschaak General Interior Topics 8 02-28-2009 05:25 PM
Fabric interior walls - why not? malconium General Interior Topics 10 06-10-2008 11:27 PM
Padded fabric on the walls (rear bedroom) Joe Z Upholstery, Blinds, Walls & Interior Finishes 5 03-08-2004 08:54 AM
