Old 06-08-2013, 08:12 PM   #1
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Excella ceiling mounting?
Howdy!
Anyone have pics or wisdom on how ceiling is mounted!? This would be on our 1999 34' Excella
I need to run supply wire and condensate tubes but do not want to just force my way through.
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-11-2013, 06:02 AM   #2
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
It is riveted to the ribs, same as the walls. If you look at your wiring diagram the wires come up the walls and across to the lights, vent fans and ac. No wires run the length of the ceiling. What you will find under the aluminum is insulation and you will be blocked at each rib from pushing the wires through.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 07-11-2013, 06:53 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Thank you Chaplain!
Channing
WBCCI# 30676
What makes an Excella an Excella? MaraLindstro 1990 - 1993 Excella 16 07-08-2012 11:05 PM
'88 Excella tail light bexel (or mounting frame) okiedebi Lights - Interior & Exterior 0 06-18-2011 02:10 PM
Bedroom ceiling fan switch? seacure 1987 - 1989 Excella 1 04-30-2011 04:45 PM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
