Old 06-27-2016, 01:14 AM   #1
Pygmypoacher's Avatar
Black Diamond , Washington
End caps finished - full reno
Just completed the end caps in my renovation of my thirty one foot '79 Sovereign Intl. Time consuming but not too hard. I used 5052 .040 and Olympic rivets. Still have to snip and shave them. But there's time for that later. Now onto the full sheets. Click image for larger version
ID:	265278Click image for larger version
ID:	265279Click image for larger version
ID:	265280Click image for larger version
Pygmypoacher is offline   Reply With Quote
Old 06-27-2016, 04:26 AM   #2
Seattle , USA
Looks great!
Why are the center strips a different/matte finish?
RareStream is offline   Reply With Quote
Old 06-27-2016, 06:43 AM   #3
Originally Posted by RareStream View Post
Looks great!
It's laying 90 from the others. used a section of the 4' x 12' sheet that was left over from cutting the narrow strips and the only way it would work was to turn the section.
Old 06-27-2016, 06:53 AM   #4
I used the process laid out here and substituted the wider center piece myself. http://airstreamcalledtrouble.blogsp...ction.html?m=1
Old 06-27-2016, 11:06 AM   #5
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
san francisco , California
are they compound or flat panels for exterior / interior?
twolanehwy is offline   Reply With Quote
Old 06-27-2016, 11:15 AM   #6
Flat. Being narrow they do better conforming to the curves. Cleco as each hole is drilled is key. I wound up lining up the short edge on the rib, setting three rivets, and flattening the panel against the 1.5" foam insulation blocks and setting one rivet by the window. The rest of the rivet holes can be drilled without the stress of holding the panel. I predrilled one long and one short side of each like in the 'Trouble' blog. Drill the short side in three spots, the outer two are drilled half inch in from the long edges. That way when you go to set the next panel you only have to pull the cleco and pin both panel corners to the rib 1" total overlap and drill the next two.
Old 06-27-2016, 04:26 PM   #7
AudioMike's Avatar
1966 22' Safari
Englewood , Colorado
Looks Great!
Audiomike
1966 Safari
2001 Silverado 2500HD
AudioMike is offline   Reply With Quote
Is this the end of my end caps? unit13 Upholstery, Blinds, Walls & Interior Finishes 9 01-02-2017 10:42 AM
Just finished a great Airstream Full-timing Summer Read AlumFalcon Off Topic Forum 6 11-25-2014 07:37 PM
Starting a full reno '58 26' Overlander flyinguy Interior Restoration Forum 9 05-28-2010 11:59 PM
What kind of interior paint 1971 Overlander/End caps dingy riverdreamer Upholstery, Blinds, Walls & Interior Finishes 5 05-24-2004 09:36 AM
