Old 04-07-2013, 10:27 AM   #1
stacyrwarren's Avatar
1970 31' Sovereign
Durango , Colorado
End Cap and Center Piece
I just finished stripping the vinyl from the aluminum walls on the side... much to my dismay... I discovered that the end cap and center were not aluminum... what is it and what would be the best for stripping the nasty paint off of it? Thanks!
stacyrwarren is offline   Reply With Quote
Old 04-07-2013, 12:14 PM   #2
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
it's fiberglass in my 62. i used aircraft stripper to remove zolatone on mine. you have vinyl, i don't know how to get it off.
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 04-07-2013, 12:58 PM   #3
1986 31' Sovereign
Miami , Florida
My end caps are very delicate (almost egg shell thin) plastic, probably PVC.
I would not put a chemical stripper on them. I sanded them smooth ( finishing with 300 grit) primed them with Zinzer and painted them. Three years, knock on wood, and they still look great.
Do an advanced search on end caps and you will find lots of solutions.
Mike
Old 04-07-2013, 01:56 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
End domes are vacuum formed ABS sheet plastic. Not only are they thin in some areas, but if they are old, they are usually brittle.
