03-18-2018, 02:34 AM
1981 27' Excella II
Clovis
Dumb question about pop rivets
I need to put up 8 pairs of hold-downs for blinds. Each has two screws. Should I use my new pop riveter to put them in? Otherwise I’m counting on a lot of screws staying in with little support.
03-18-2018, 06:11 AM
1995 25' Excella
xxxxx
, xxxxxx
I would rivet them.
03-18-2018, 07:21 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
When you drill the holes, for either screws or rivets, be sure to use a positive stop on the drill bit to keep from having a whoops. I use a block of wood with a hole drilled through thick enough to allow about 1/2 inch of the bit to protrude. It is awful easy for a bit to catch on the Al and self feed.
If there is room for the riveter head I would use rivets.
03-18-2018, 07:45 AM
1972 25' Tradewind
Denver
Seems like you answered your own question. ;-)
Rivets are almost always better in an airstream. Vibration from travel will cause screws to back out over time. Rivets stay put. If your pop riveter head is to large to get close enough to the blinds, use a little dab of silicon or something similar with your screws to keep them from rattling loose. And as Bill said, don't overtighten the screw, or it won't hold and then you'll just have an extra hole!
25' 1972 Airstream Trade Wind Land Yacht
2006 Jeep Liberty CRD (diesel)
http://BeahmStream.com
03-18-2018, 07:51 AM
1993 34' Excella
Estancia
, New Mexico
Lisa, What are you using for blind hold downs?
03-18-2018, 09:39 AM
1981 27' Excella II
Clovis
I have Levalor cellular shades; as mounted, when the are pulled down, they hang straight and sway a good 2” away from the base of the window. By using the hold down, they flush up against the wall at the base creating better light blockage & privacy. Previous owner used Velcro and it was a sticky dirty mess that I have spent hours cleaning! They snug up when closed, during travel & are not a problem at all. Do you know of a better solution? I’d appreciate it.
03-18-2018, 09:43 AM
1993 34' Excella
Estancia
, New Mexico
I have the same problem with my mini blinds. Looking for a good solution.
03-18-2018, 10:07 AM
Central
, Mississippi
I attached a small magnet to each end of the pull down and screwed a 1" washer to the wall. Pull down the blind and push it to the wall, the magnet grabs the washer and holds it to the wall.
03-18-2018, 10:12 AM
Merkel
Several years back on the forum, someone suggested mounting small magnets on the window frame to hold the mini blind base at the bottom securely. I found small square magnets with a screw hole in the center and mounted them on the frame. No more dangling mini blinds even after towing for several hours. Thanks to the op on that.
03-18-2018, 11:58 AM
1991 35' Airstream 350
Barry's Bay
, Ontario
When drilling I would suggest placing a small (app. 1/4”) peace of copper tubing over the bit .
About a half inch shorter than the bit to stop and dint to the outside panels
Howard and Ann Schutt
03-18-2018, 02:59 PM
1970 23' Safari
1985 25' Sovereign
Mequon
, Wisconsin
When I use screws to anchor anything, rather than drill a hole, I use a ice pick taped gently with a hammer to create a hole that then has extra material in contact with the screw
03-18-2018, 03:58 PM
"Silver Shrek"
2000 27' Safari
Crestwood
, Kentucky
Or put masking tape on the drill bit to mark depth
03-19-2018, 06:54 AM
2008 19' Bambi
2012 23' Flying Cloud
Bandera
Would not have thought of that....
03-19-2018, 06:56 AM
2008 19' Bambi
Bandera
Would not have thought of that.....
