Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 09-16-2002, 04:51 PM   #29
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
I can get the end caps, ifthey are still available. But I need your serial number and which cap do you need/ Front or rear?
inlandrv.com
airstreamparts.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 09-16-2002, 04:59 PM   #30
cotopaxitwo
Profile:
I need the front cap. and my serial # is I25 T9J 2062
cotopaxitwo is offline   Reply With Quote
Old 08-28-2004, 05:52 AM   #31
jperryfly
Profile:
Interior Lights
Has anybody tried the flouresent lights? If so which size did you use?
On the subject of end caps... you can get plastic welding kits from places like Harbor Freight and Lowes sells paint and primer made for plastic. I used it on my AC cover, which was yellowed and it worked great.
jperryfly is offline   Reply With Quote
Old 08-28-2004, 08:50 PM   #32
53flyingcloud
53flyingcloud's Avatar
Profile:  Amherst , New Hampshire
Just revisited this thread after so many moons..
Since then, I have picked up an older A/S to add to our collection...lol
One thing I notice is: The end caps in my '64 GT is made from fiberglass material and still looks as good as it did the day it was new..Amazing~No cracks, nothing~
ciao
53FC
53flyingcloud is offline   Reply With Quote
Old 08-29-2004, 08:41 AM   #33
McMullen
Profile:
Since I'm stripping the inside of my AS because its so filthy and water damaged. Ive been quite loose in experimenting with differant cleaning things. Ive found that plain old oven cleaner, whitch is lye will clean the end caps to sperkling white. It will also eat the aluminum. But I was very carefull and it was the only thing I found that would do the job. WARNING this is a 1967 Overlander and I Do not know what the end caps are made out of. But I'm sure a little testing in an inconspicuos place would not hurt.
Mac
Eschew Obfuscation
McMullen is offline   Reply With Quote
Old 08-29-2004, 08:59 PM   #34
JohnG
JohnG's Avatar
Profile:
The Oven Cleaner is something that I may try on mine. I have looked several times at that dull dingy looking yellowish end cap and thought if I could just paint it an off white it would sure liven up the inside look. Has anyone else tried the oven cleaner, and what results can you report?
As far as the lights go, well mine are shot too, but I am going to be replacing them with some homemade ones if we can get them looking good, and if not we will just buy new ones.
Just adding my 2¢ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 08-29-2004, 11:16 PM   #35
Shelby Copeland
Profile:
Wink Yellow End Caps
I had great success painting my ugly yellow end caps on my 1974 Tradewind. I used krylon Fusion spray paint that I bought at Wall Mart. The color I selected is Dover White. It blends very well with my interior walls. I cleaned the caps as well as I could with 409 and then used clear water to rinse them down and allowed them to dry. I then masked and painted. Be sure to cover all horizontal surfaces in the trailer because the paint spray will drift and accumulate on them. I did this last November and they still look great after sitting through a summer of New Mexico heat. I was so impressed with the way they turned out that I also used the paint on my shower stall and pan as well as the counter top in the bath room. Good luck. Shelby
Shelby Copeland is offline   Reply With Quote
Old 10-15-2004, 12:57 AM   #36
RiskIt
RiskIt's Avatar
Profile:  1972 25' Tradewind
Lake Worth , Florida
Anyone thought about covering the cap's.... If you look at speaker boxes that people make for there car's you'll see it. No not orig. but could look great. I have some faux leather I'm going to try. I've redone (in the middle of) so I don't have to stay original.
Use glue, heat and it should look great. (I hope)
RiskIt is offline   Reply With Quote
wood walls in an A/S? Dave Cole Upholstery, Blinds, Walls & Interior Finishes 26 03-10-2008 11:35 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
