Old 09-16-2002, 04:51 PM   #29
I can get the end caps, ifthey are still available. But I need your serial number and which cap do you need/ Front or rear?
inlandrv.com
airstreamparts.com
Old 09-16-2002, 04:59 PM   #30
I need the front cap. and my serial # is I25 T9J 2062
cotopaxitwo is offline   Reply With Quote
Old 08-28-2004, 05:52 AM   #31
Interior Lights
Has anybody tried the flouresent lights? If so which size did you use?
On the subject of end caps... you can get plastic welding kits from places like Harbor Freight and Lowes sells paint and primer made for plastic. I used it on my AC cover, which was yellowed and it worked great.
jperryfly is offline   Reply With Quote
Old 08-28-2004, 08:50 PM   #32
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Just revisited this thread after so many moons..
Since then, I have picked up an older A/S to add to our collection...lol
One thing I notice is: The end caps in my '64 GT is made from fiberglass material and still looks as good as it did the day it was new..Amazing~No cracks, nothing~
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 08-29-2004, 08:41 AM   #33
Since I'm stripping the inside of my AS because its so filthy and water damaged. Ive been quite loose in experimenting with differant cleaning things. Ive found that plain old oven cleaner, whitch is lye will clean the end caps to sperkling white. It will also eat the aluminum. But I was very carefull and it was the only thing I found that would do the job. WARNING this is a 1967 Overlander and I Do not know what the end caps are made out of. But I'm sure a little testing in an inconspicuos place would not hurt.
Mac
Eschew Obfuscation
McMullen is offline   Reply With Quote
Old 08-29-2004, 08:59 PM   #34
JohnG's Avatar
The Oven Cleaner is something that I may try on mine. I have looked several times at that dull dingy looking yellowish end cap and thought if I could just paint it an off white it would sure liven up the inside look. Has anyone else tried the oven cleaner, and what results can you report?
As far as the lights go, well mine are shot too, but I am going to be replacing them with some homemade ones if we can get them looking good, and if not we will just buy new ones.
Just adding my 2 worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 08-29-2004, 11:16 PM   #35
Wink Yellow End Caps
I had great success painting my ugly yellow end caps on my 1974 Tradewind. I used krylon Fusion spray paint that I bought at Wall Mart. The color I selected is Dover White. It blends very well with my interior walls. I cleaned the caps as well as I could with 409 and then used clear water to rinse them down and allowed them to dry. I then masked and painted. Be sure to cover all horizontal surfaces in the trailer because the paint spray will drift and accumulate on them. I did this last November and they still look great after sitting through a summer of New Mexico heat. I was so impressed with the way they turned out that I also used the paint on my shower stall and pan as well as the counter top in the bath room. Good luck. Shelby
Shelby Copeland is offline   Reply With Quote
Old 10-15-2004, 12:57 AM   #36
RiskIt's Avatar
1972 25' Tradewind
Lake Worth , Florida
Send a message via AIM to RiskIt Send a message via Yahoo to RiskIt
Anyone thought about covering the cap's.... If you look at speaker boxes that people make for there car's you'll see it. No not orig. but could look great. I have some faux leather I'm going to try. I've redone (in the middle of) so I don't have to stay original.
Use glue, heat and it should look great. (I hope)
RiskIt is offline   Reply With Quote
wood walls in an A/S? Dave Cole Upholstery, Blinds, Walls & Interior Finishes 26 03-10-2008 11:35 AM
