Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 12-02-2011, 09:57 AM   #1
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 13
Dry Cleaning 02 Safari Curtains?
I took my 02 Safari curtains to the dry cleaners today. The clerk who waited on me was not sure that the small plastic track parts on the curtains could make it through the dry cleaning process. She was concerned that the chemical would melt the plastic parts. Any of you have experience drying cleaning Safari curtains and did the plastic parts survive?
Ridgerunner3 is offline   Reply With Quote
Old 12-02-2011, 10:16 AM   #2
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
I've heard a lot of people complaining that they shrink when dry cleaned. I use "Clean Earth" dry cleaners and they do a great job without all the nasty chemicals. I did a quick search and there are not any in your area, Nashville is the closest Clean Earth dry cleaner to you.
http://www.greenearthcleaning.com/
There are also posts of people that cleaned them at home with good results. Just do a search for cleaning curtains.
Good luck,
Get involved and sign up for a Rally!
https://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 12-02-2011, 11:10 AM   #3
2006 28' International CCD
Nashville , Tennessee
I washed ours with Woolite in my front loader on delicate cycle (cold water). Then "hand pressed" them flat to dry. Touch up with warm iron. No problems and they look great. I don't think I would put them in a top loading washing machine but would hand wash instead.
Good luck,
Debbie
dmoore is offline   Reply With Quote
Old 12-02-2011, 03:00 PM   #4
2002 25' Safari
Images: 13
Thank you for the information. I do not have a front loading washer. I know that others have had good luck washing the curtains. The owners manual says to only dry clean these particular curtains. I am concerned about damaging that much fabric. There are 14 curtain panels in our Safari. I'll check into green earth cleaning. I'll let you know how this turns out.
1968 Safari 22' :: 1968 Airstream Safari Darrengj Airstream Registry Discussions 1 02-09-2020 07:28 AM
New Airstream Curtains Silver Threads Commercial Listings 11 05-14-2015 09:24 AM
1969 Safari - cleaning the Interior walls VeggieBullet Upholstery, Blinds, Walls & Interior Finishes 12 10-19-2011 05:05 PM
